Paul Birkeland · 480937
https://www.mouser.ie/datasheet/2/358/typ_DEH-1275811.pdfCame across these on Mouser, they are targeted at the mhz range but i wonder if they would suffice to stop ground loops in audio equipment?
They are 25 freaking dollars each if you buy 50 at a time!
I would absolutely not use surface mount diodes in this application.Order 1N4001, 1N4002, 1N4003, 1N4004, 1N4005, 1N4006, 1N4007, UF4001/2/3/4/5/6/7.
The maximum peak signal voltage you could send into a Crack with the volume control all the way up is 1.5V. If you have 500mV peak of noise current because of a polluted ground, that's not a small voltage at all!
If I understand the paragraph correctly, the noise current is coming from the ground pin in your power outlet / power strip, and the pair of twisted diodes is to block the noise current from entering the Crack, am I correct?
Usually, what we call "ground loop" hum/buzz comes from capacitive coupling from the power transformer primary winding to the signal amp power supply secondary (the high voltage in tube amps). The capacitance is small, on the order of 100pF, so it presents a high impedance at power line frequencies and can be shorted to ground through a 10-ohm resistor. The diodes are there in case there is a fault that presents a low-impedance source, such as a short from the power line to the signal ground. In normal use, they are not active and have no effect.
