Left Channel is slightly louder than the Right [resolved]
undertowogt · 17057
Offline undertowogt
Hello,
I have had my reduction for a while and always noticed the Left Channel is slightly louder than the Right. I ran signal through my audio interface and digitized it and it is about 2 db difference. Even when I move Tubes around to troubleshoot, the left channel is louder .Vocals always seems to be shifted to the Left. The problem is surly coming from the reduction as I have trouble shot cables, amp and everything else including my cart and turntable setup. If it is NOT the Tubes what could it be.........any thoughts. I am going to do A voltage check tonight.
« Last Edit: July 05, 2019, 04:31:33 PM by Paul Birkeland »
Reply #1 on: June 24, 2019, 09:39:26 AM
This is very, very, very, very likely to be bad solder joints.  I would go through the Reduction and reflow all of them.
You can generate a 60Hz tone and feed it through the amp to check for signal levels in various spots, but I wouldn't go to this just yet.  I'm pretty sure you have some grounds that aren't well grounded.
Offline undertowogt
Reply #2 on: June 24, 2019, 02:29:46 PM
Solder will be flowing after the kids are in bed tonight. I will update later,
Update: So I re flowed solder last night and did improve on some solder joints. Unfortunately the problem still exists. I did another signal capture with my audio interface to be 100 percent sure. When capturing I add no gain on the channels of the audio interface to be sure the signal is direct from the phono preamp. My Captured Waveform is consistently off balance by about 2db. I can see this is the Phase analysis and the Freq analysis and the waveform itself as well as hear it shifted in the sound stage.
The capture is: Record Player> Reduction>Audio Interface>Capture computer.
« Last Edit: June 25, 2019, 03:23:43 PM by undertowogt »
Offline undertowogt
Reply #3 on: June 29, 2019, 04:22:45 PM
How hard is it to pump signal into the reductions to check for signal levels in various spots as you suggested?
Reply #4 on: June 29, 2019, 04:34:57 PM
If you have a cell phone and an 1/8" mini to RCA adapter, you can download a signal generator app and send a 60Hz sine wave tone into the Reduction.  You want to be careful to have the volume at the lowest possible setting on your phone though (one up from muted).
Offline undertowogt
Reply #5 on: June 29, 2019, 05:01:33 PM
Hi PB,
I have a 60hz tone and all, thats the easy part for me. Unfortunately I am not an electronics wizard like a lot of DIYers out there and I dont understand how to go about checking signal levels in Various spots. Is this done with a multi meter?
Would I be correct in saying that I should be trouble shooting the Lower Channel and NOT the higher volume channel?
« Last Edit: June 29, 2019, 05:16:55 PM by undertowogt »
Reply #6 on: June 29, 2019, 05:22:30 PM
You should troubleshoot both channels!  In a phono preamp, the EQ pulls the signal down significantly everywhere except the low bass, so while my opinion is that you have a flaky solder joint on a ground wire in the offending channel, you could also have a bad EQ connection in the channel that seems to be good.
To measure the signal voltage, you will need a meter set to AC volts.  Your meter will need an AC volt scale that's pretty low, most of them will have a 2V setting or a setting that looks like mV~.  If you meter only has something like a 200V and 500V (or 200V and 700V) scale, then it won't quite get the job done.  The $25-ish meter at Harbor Freight is perfectly adequate for this job.
To get your bearings, you can hook your phone up playing a 60Hz tone to the Reduction with the Reduction powered off, then crank the volume up all the way on the phone and measure AC voltage between the center pin and ground on each input jack.  For most phones, this will be about 0.3V (300mV).   For the remainder of the tests, you'll want to turn your phone down so it's at 10mV or less.
Offline undertowogt
Reply #7 on: June 29, 2019, 05:34:28 PM
It could be an EQ issue as you say. The Channels differ slightly in EQ. The right channel is slightly thinner sounding and the Left Channel has a tiny bit more bass. This may also bring the signal level down or up slightly I would think as EQs do.
Where exactly is the EQ section of the reduction. I will take an even closer look. Ok , thanks for the tips.
Reply #8 on: June 29, 2019, 05:40:49 PM
Another possibility is that you have a 47K and a 475K resistor swapped.
The EQ is the 75K, 10.7K, and all the 0.01uF caps.
Offline undertowogt
Reply #9 on: June 30, 2019, 06:09:25 AM
I looked at the resistors, They are in the correct position. I also checked the grounds again and they look solid. I am kinda of stumped now. I will do a Voltage check later and update.
Offline undertowogt
Reply #10 on: July 02, 2019, 05:30:23 PM
After closer inspection I noticed that the red wire attached to a tube pin with the 1 .0μF 50V (Z5U) capacitor was lose. It was still touching with pressure so the reduction was still working, maybe it recently came lose. I soldered it on correctly and plug the unit in to test. Unfortunately, Now I have a new problem........ both channels distorting significantly. So I pretty much made things much worse. I think the channel are balanced now ( somewhat hard to tell with the distortion though)
I am away for a few days and will have to take a closer look when I return.
Reply #11 on: July 03, 2019, 04:20:50 AM
Go back and recheck your voltages.
Offline undertowogt
Reply #12 on: July 04, 2019, 05:58:34 PM
I checked Voltages. Some seem a little lower then they are supposed to be?:
Terminal Voltage (DC)
3
4     147.2
5
6
7      72.7
8
9
10
11
12
13    67.0
14    67.6
15
16
17
18    67.3
19    62.5
20    61.9
21
22
23
24
25
26    67.2
27
28
29    146.9
30
31    71.5
32
33    5.6
34
35
36
37    5.6
38    9.7
39    3.5
40
41    3.7
42    9.7
43
44    181.6
45
46
47
48
49
50    164.1
51    164.1
52    181
53    181.3
54
55
56    146.8
57    146.8
58
59    164.3
60    164.3
61
62
Reply #13 on: July 04, 2019, 06:20:53 PM
The 5.6s are concerning.  Can you post photos of the two 5 lug terminal strips where the axial blue capacitor is mounted?
Offline undertowogt
Reply #14 on: July 05, 2019, 06:48:56 AM
Pic Doc
