Eros 2 Help 2
adeep42 · 4792
Reply #15 on: July 03, 2019, 07:04:14 AM
The one that's closer to the center of the long edge on the board, not the one by +reg.
Offline adeep42
Reply #16 on: July 03, 2019, 07:11:53 AM
I don't see an X on that part of the board
Reply #17 on: July 03, 2019, 07:12:52 AM
This?
Offline adeep42
Reply #18 on: July 03, 2019, 07:23:10 AM
Sorry, it was obscured by the cap.
2.48 vDC
Reply #19 on: July 03, 2019, 07:26:40 AM
If you have 2.5V (2.48 is close enough) on that X terminal on the B side but Kreg is 0.6V on the same half of the board, you most likely have a miswire from the Kreg terminal to the D socket, or an ungrounded grid (D2 and D7 are the grids).
When you said before that you got "good readings" in your shunt regulator test, what were those readings exactly?
You seem to have about the same problem you had previously.  It might be a good idea to go over the solder joints on the board above the D socket again.
Offline adeep42
Reply #20 on: July 03, 2019, 08:15:15 AM
Hi Paul,
Think it's time to send this puppy to you.
Please advise.
Alan
Reply #21 on: July 03, 2019, 09:42:26 AM
