Need Help with First Tube Build - WE91 300B Parafeed Derivative
EricS · 95311
Offline EricS
    • My DIY Home Theater
For the past two years, I've been gathering parts for a new tube amp - the Magnequest iron took the longest time to track down and several of you here have contributed - thank you.  I have built lots of solid state stuff, but this will be my first tube amp.  The design is Paul Joppa's parafeed update to Joe Roberts' Western Electric Model 91 300B that was published in Sound Practices in the Summer 1992 issue.  Paul has graciously granted his permission for me to post his design and my thread here.  Thank you, Paul!
This build will likely take me several months to complete from here.  Since this is my first tube build, I'm likely to need a fair amount of guidance in the form of "hey, dummy - don't do that!"  I have read Morgan Jones' "Building Valve Amplifiers" and have tried to incorporate his long list of physical layout guidelines, though I'm sure I have missed several fundamentals.
Attached are Paul's schematic (I have added all of the parts values) and my first attempt at a 2-dimensional layout the physical components (quick and dirty Visio drawing - for easy rearranging over time).  The overall top plate as of now is 11" x 17" and each of the parts is drawn relatively close to actual scale.  The final layout will likely be a little smaller in footprint.  The blue components will be mounted on the top of the plate, the orange components will be hidden on the bottom of the plate.  I have aimed for both visual appeal (physical symmetry of top-of-plate parts) and what appears (to me, at least) to be a reasonable first pass at an electrical layout.
Here is where I need your help:  What have I done wrong?  Which parts should not be next to one another?  How can I improve the parts layout to improve running wires or preventing unwanted interactions?
My ongoing thanks and appreciation in advance!
« Last Edit: July 30, 2019, 04:58:40 PM by EricS »
Eric
Offline Tom-s
The book you've read is the first thing i'd recommend to reread  :P. It covers all basics on tube amp layout. With every layout i try, i'd reread it several times and combine this with the BH manuals i own. To see what practices i could improve on, even after the breadboard. Searching the internet for completed versions of your amp also helps a lot ime.
I'd advice on revisiting the pages about transformer and choke orientation relative to eachother (there's always room for improvement).
The most important part is your grounding scheme, make this your first step in the build. The book is a good reference for this, but here's another good link: https://www.aikenamps.com/index.php/grounding
Good luck with your build.
I think you have the PGP 8.1 and the TFA-2004 aligned.  To double check this, tile print your layout to scale, set the parts on the piece of paper, then take another photo.
I would also double check with PJ to be sure that L3 and L4 are separate parts.  I suspect they are intended to be different windings on the same choke.
L3 and L4 are separate, since for this I wanted to specify readily available parts (except for the Magnequest items - I did this design for the MQ forum).
Do you have a part number for your R1?
Offline EricS
Tom - thanks for the link to the Aiken Amps article on grounding.  I'm reading it now.  I also have been looking at a few of the Bottlehead builds that people have documented  in various places as well as some kit manuals of various origin.  I see that many of the Bottlehead kits feature star grounding.  The Aiken concept of multiple stars (PSU, small signal) looks interesting.  I'll have to draw out some wires on my diagram and see how to optimize major components to keep things clean.
Paul B - I used this resistor RH05050K00FE02 : https://www.mouser.com/ProductDetail/Vishay-Dale/RH05050K00FE02?qs=sGAEpiMZZMtbXrIkmrvidDNaDpN5VXc5qswg6VdgV68%3D  Not sure if it was the "normal" or "non-inductive" variety that I purchased, I'll have to check my invoice.  Good eye, my power and output transformers are not quite aligned - this is an easy fix.
Paul J - Thanks for the confirmation.  I take it from our previous email that asymmetry in the chokes for the DC filament supply is not really a problem if I'm trying to hit a specific voltage target.   Is stacking these chokes OK for conserving physical space under the chassis, or should they be mounted 90 degrees to one another to avoid interactions?  Or will arranging them 180 to one another provide some benefit if they are stacked or physically parallel to one another?
Eric
I'm glad you went up a size.  Those chassis mount resistors get really hot without a huge heatsink as you approach a small percentage of their rated power, but with a 50W one I think you'll be OK.
If the coils on the TFA-2004 and PGP8.1 are aligned in your photo, I would recommend rotating the PGP8.1 rather than the TFA-2004.
Offline EricS
PB  - Yeah, I thought moving from 25w to 50w for the bleeder resistor would be a good move.  The data sheet still indicates a pretty steep derating curve, even when the resistor is mounted to a 12" x 12" metal plate.  I also adjusted the PGP transformer orientation and added some detail in the diagram to indicate the direction of the transformer laminations for clarity.
I'm working on seeing what the grounding/wiring layout looks like with this parts arrangement.
Eric
Offline Tom-s
Where did you find 40uf MBGO's? I'm planning on the same as cathode bypass for the SII 2a3, but only found 30uf as largest size (so settled on using 2/channel if it fits). A single 40uf would sure help.
Offline EricS
Ah - you've caught me.  My 40uF MBGO is actually two individual 20uF 160v caps.  Compared to the paper and tin foil caps, these are pretty small.  I like them because they have a nice mounting tab welded across the bottom.    I measured all of my Russian caps for leakage, the MGBO had about 1uA of leakage on my meter.  I also charged them up to 150vDC and let them sit for 24 hours.  After this time, two of them had only 8% of their initial charge left, one had 26% left, and the best of the lot had 40% of the initial charge after a day.  I'll see how they perform in the amp.  If they don't work out, the MBGO will get replaced with an ASC 45uF big can cap.
The OKBG are paper and tin foil and performed much better.  I could measure no leakage on my meter and these all had about 70% of their initial charge (350vDC) remaining after 24 hours.  I figured none of this was very critical as they are all bypassed by resistors that will drain them much faster than their own internal discharge rates will.
The Aiken Amps paper on grounding is an excellent resource.  I've read it several times now, making notes along the way, and have a trivia question for the crowd:  Is Star grounding or Buss grounding preferred?    I'm thinking this design lends itself nicely to using three star grounds, one on each of the main 20uF caps to make increasingly "quieter" ground points.
« Last Edit: August 03, 2019, 04:07:02 AM by EricS »
Eric
Offline Bardamu
Reply #10 on: August 03, 2019, 06:04:02 AM
Hello,
This drawing from A Dutch side is the way i usually do it.
And i always follow the advice to keep wires between transformer, rectifier, input choke and first capacitor at a minimum length.
Greetings, Eduard
P.s i hope attaching worked
Offline EricS
Reply #11 on: August 03, 2019, 07:11:46 AM
Interesting, that looks like two stars: one for the psu, a second for the amp section...
Eric
Offline Bardamu
Reply #12 on: August 03, 2019, 07:39:33 AM
Hello Eric,
Their explanation. The closer the cap is to the transformer/ rectifier combination the bigger the current will be so that connection should be short. The last capacitor in the power supply they regard as a part of the circuit itself. There should not be much of a ripple left to take care off.
Greetings, Eduard
P,s i think i will try to get the majority of the caps/ the number of mF have their return to the spot located close to the transformer and then have a cap like 10 mF right next to the output transformer??
Reply #13 on: August 03, 2019, 07:43:41 AM
This is absolutely true in a series feed amp, but far less important in a parallel feed amp, as the parallel feed cap takes over the lion's share of this duty.
Offline Bardamu
Reply #14 on: August 03, 2019, 09:27:03 AM
Hello Paul,
Is this comparable to my future amp as seen in the attachment where a so called ultrapath cap is used.
They say it takes the power supply caps  out of the circuit. But what is also does is injecting noise from the power supply into the circuit. So they say the power supply must be dead quiet.
So one must take care of this by using good parts in the supply. But the quality of the ultrapath must be top notch too i guess.
Greetings, eduard
