Hissing when connected to laptop
benzxc · 6672
Offline benzxc
Reply #15 on: August 10, 2019, 08:39:46 AM
So I went ahead and trimmed some remaining excesses and tightened a few screws here and there.
The weird very very low volume hiss (I almost have to "look" for it) is still there - although it is not there all the time.  I find that I can get rid of it simply by unplugging the headphone jack and replugging it.  It is a little weird, because it is  independent of the RCA jacks and independent of volume control.  Anyone has similar issues?  Maybe I might have to try a few other tubes?
Apart from this little issue, the crack w/speedball upgrade works beautifully and it has been a great few days working on this.
Ben
Ben Chiou
Offline Tom-s
Reply #16 on: August 10, 2019, 08:44:05 AM
Have you checked the pointed out resistor by PB?
This could explain your issue and destroy headphones when not properly solved.
Edit: the fact that mechanical influence at the headphone jack changes the sound point to a mechanical problem.
I suspect a solder joint or the resistor mentioned before.
You could try tubes, but that wouldn't explain the influence when fiddling at the headphone jack.
Edit 2: What he says. (points down)
« Last Edit: August 10, 2019, 08:47:50 AM by Tom-s »
Reply #17 on: August 10, 2019, 08:45:46 AM
Also if you have a noise that changes when you plug and unplug the headphone cable, that is indicative of a loose connection, not a bad tube.
Offline benzxc
Reply #18 on: August 10, 2019, 08:53:50 AM
Thanks, Paul, Tom,
Can you point out again which resistor connection I am missing? I attach a new photo again. I was a little unsure of which one in PBs previous post.
Ben
Ben Chiou
Offline oguinn
Reply #19 on: August 10, 2019, 08:54:06 AM
That black wire going to the headphone jack looks like it has a good bit that's bare wire (the jacket was stripped kind of far back), and that could be hitting the top plate or interacting with something. Might want to wrap some electrical tape or insulating material around it.
Jameson O'Guinn
Offline benzxc
Reply #20 on: August 10, 2019, 08:59:26 AM
Thanks, Jameson.  Will do.
Ben Chiou
Offline Tom-s
Reply #21 on: August 10, 2019, 09:13:22 AM
Thanks, Paul, Tom,
Ben
Look at the more proximal (left) part of the bottom 2.49k resistor, it shows a weird / sharp angle, a possible break.
Offline benzxc
Reply #22 on: August 10, 2019, 09:21:54 AM
Thanks, Tom.
I attach a photo from another angle. It doesn't appear cut to me.
Ben Chiou
Offline Tom-s
Reply #23 on: August 10, 2019, 09:38:24 AM
I still suspect a bad solder joint somewhere. First, go over all ground connections (trace back all black wires, look for loose or flaky connections) and see that all screws with a ground connection are properly tightened.
When not succesfull.
Get some cheap headphones out. Plug them in. Plug in a source without any sound. Flip crack over on some stands (and put the power switch to on). Plug the powercord in. Get out a wooden (non conductive) chop-stick and start poking at the joints (start around the jack) untill you reproduce the hissing sound, that's your bad joint. Be very careful when doing this.
Edit: forgot to say. Indeed that resistor looks good in this picture (unlike in the one on the previous page)
« Last Edit: August 10, 2019, 09:40:01 AM by Tom-s »
Offline benzxc
Reply #24 on: August 10, 2019, 09:41:28 AM
Thanks, Tom.  Will do.
Going to get some shut eye now.  It is 3:40 AM in the part of the world where I am located... been the third night I've stayed up this late since I started building the crack.
Thanks for all the help.
Ben
Ben Chiou
Reply #25 on: August 10, 2019, 10:48:14 AM
That other photo you provided shows that the resistor lead is bent a little bit, not cut.  It looked suspicious at the alternate angle, but not so much now.
Offline benzxc
Reply #26 on: August 10, 2019, 07:24:09 PM
So I went back and resoldered all accessible joints and tightened all screws again to no avail. Then, I did the chopstick test and didn't hear any joints that made the hiss/hum.  The hiss/hum just seemed to be there all the time.
I also noticed the hiss doesn't start immediately after I turn the amp on. Rather, it starts a few minutes after the amp is turned on.
I ordered a set of new tubes just to rule that out as a source of issue. Otherwise, I'm kind of at a loss now and am thinking of maybe sending it back to bottlehead for repair.
Ben Chiou
Offline benzxc
Reply #27 on: August 11, 2019, 02:26:45 AM
Hi all,
Happy to report that having left the newly built crack w/ speedball upgrade on and playing music for 10 plus hours, the right channel hiss seems to have gone away.  I have checked many times over the past 2 hours and it has not resurfaced.  Needless to say that I am a happy camper now! :D   Will keep monitoring to see if the hiss comes back.
Thanks again,
Ben
Ben Chiou
Offline benzxc
Reply #28 on: August 11, 2019, 04:39:31 AM
Oh no!  It has come back......... :(
Ben Chiou
Offline bernieclub
Reply #29 on: August 11, 2019, 06:00:04 AM
Not sure if you've cleaned the tube pins, but I have exorcised various gremlins by doing so.
Bernie
Bernie Zitomer
