I need ideas for a subwoofer to go with Blumenstein Orca's and the Stereomour.
ALL212 · 2289
Offline ALL212
I've got the old style Orca's coming in (running the new version now to tide me over until the old style are done - long story...) and am running them on the Stereomour V1.  They certainly need a sub and at the moment I'm back on the budget.
Any recommendations for a small, powered sub?  At or under $300?  $200 would be better.  Crossover would be at 90 to 100 hz and I'm not looking for crazy low end bass.  If it'll touch into the upper 30hz I'd be happy.  DIY ideas are welcome.
I've not played in the subwoofer arena successfully before.
Aaron Luebke
Here's a tiny one, though it looks like you'd need a dedicated amp:
https://www.parts-express.com/dayton-audio-6-1-2-down-firing-passive-mini-subwoofer-kit--300-7160
Offline ALL212
Certainly fits the budget!  And I have a couple of the small '70's Sansui integrateds that should work as an amp; the AU222 and the AU3900.  I just need to split the DAC output and create a filter.
« Last Edit: September 22, 2019, 09:41:44 AM by ALL212 »
Aaron Luebke
Offline grufti
This TPA3116 amp might even have have a crossover filter and it is showing free returns for me, just in case it is total crap.
https://www.amazon.com/NOYITO-TPA3116-Digital-Amplifier-DC12-24V/dp/B07D73ND54/ref=sr_1_10?keywords=tpa3116+subwoofer+amp&qid=1569214230&s=musical-instruments&sr=1-10
Offline EricS
    • My DIY Home Theater
I was going to suggest using the CSS SDX-10 driver, but it seems there's been quite a large price increase over the past few years.  Three years ago, it sold for $140, now they want $225.  Stick it in a small sealed cabinet and add an amp...
https://www.css-audio.com/online-store/CSS-SDX10-10-XBL%5E2-Subwoofer-p110031748
Eric
Offline EricS
Another option - looks like this one is just a driver, a port, and plans to build a box for $150.  You'll need to provide an amp.  Not much other detail is given.
http://www.pispeakers.com/catalog/product_info.php/products_id/275
Eric
Offline pboser
Here's another option - cheap, unattractive (though you can take some steps to improve it) and good.  "Invented" by Ed Schilling of Hornshoppe fame.
https://www.transcendentsound.com/bucket-sub.html
I'm sure most plate amps for subs would give good results, or you can use the recommended Crown XLS amps with built in crossover.
More info here:
http://thehornshoppeforum.com/index.php?PHPSESSID=j1diebmupat1ppbg5ml9n4egb5&topic=406.0
and here:
https://tubehifi.websitetoolbox.com/post/subwoofer-project-6426090
and here:
https://audiokarma.org/forums/index.php?threads/bucket-sub-revisited.658794/
I forgot I have a pair stashed away- time to dig them out (and hide them from my wife!)
Pete
Peter Boser
Offline ALL212
Thanks for the ideas!
Going to have to sit on this for a bit as my employment status has changed.
Aaron Luebke
