Troubleshooting - found trouble...
ALL212 · 5306
Offline ALL212
on: October 04, 2019, 01:39:57 PM
A friend of mine purchased a Reduction from the 'bay.  Nice build, well done, however...
After some time horrible noises would come from one channel and in one case the speaker fuse blew.
I found a cold solder joint at 60 on the resistor.  The wire had solder all around it but was not making a solid connection.  If this resistor lost connection would it have done what he described as the symptoms?
I've reflowed the joint, ran all resistance checks and all voltage checks - everything checks fine.
Aaron Luebke
Reply #1 on: October 04, 2019, 02:17:34 PM
Yes, a loose connection there would cause the high DC voltage to be there intermittently, which could make low frequency transients to annoy a solid state amp and blow a speaker fuse.
Offline ALL212
Reply #2 on: October 04, 2019, 02:36:43 PM
Ouch...
I didn't want to test it live until I had confirmation.
As always much appreciated Paul!
Aaron Luebke
Offline ALL212
Reply #3 on: October 16, 2019, 01:42:07 PM
Follow up:
While "in the shop" I took the liberty of pulling some parts from my stock and I did some updates.  The owner reported he heard an improvement so I thought I'd list what I did here.  To be honest I didn't expect any audible improvement.
All three power supply caps replaced with Nichicon.  In doing this I discovered the issue with the cold solder joint.  I replaced one diode with a Cree Shotkey and the 3300 uF with another Nichicon.  The last power supply cap got a 2.2uf WIMA attached to it.
Aaron Luebke
Reply #4 on: October 16, 2019, 03:02:27 PM
There's some interesting points/ideas about bypassing large capacitance electrolytic power supply caps with small capacitance film cap in the recent "Bypassing Capacitors" thread on the Tube DIY Asylum sub-board ... but they are interspersed amongst a lot of totally off the rails bickering.
Lower ESR and ESL, and faster transient response are mentioned as possible benefits.
cheers, Derek
