Spark while voltage testing
Krishk · 5375
Offline Krishk
on: October 20, 2019, 03:13:01 PM
So, I finished the setup of the Crack, and once I plugged in the power source everything was normal. However, once I check terminal 3's voltage a small spark went off. Did the terminal spark because of my testing method or did I solder something incorrectly? I check all the soldering connections and they all seemed good with no incomplete joints. What should I do next?
Offline kgoss
Reply #1 on: October 20, 2019, 03:34:54 PM
Did you pas the resistance tests?
A spark usually means you touched 2 terminals with the meter probe.
I use a clip lead for the ground connection so I can concentrate on the measurement point.
Ken Goss
Offline Krishk
Reply #2 on: October 20, 2019, 03:46:58 PM
Yes I passed all the resistance tests. I have a clip for the ground as well but my hands are so shaky with the other lead probe, so I am betting I did touch two terminals. Did I ruin my kit? I rechecked all the resistances and everything was in a normal range.
Offline Krishk
Reply #3 on: October 20, 2019, 04:42:37 PM
Would it be harmful if I assume I pass the voltage tests due to passing the resistance test and plug in a pair of headphones?
Reply #4 on: October 20, 2019, 05:00:32 PM
Yes that is risky. PB will probably step in, but meanwhile just re-do the voltage checks (being extra careful about touching the terminals). Better yet, use clipleads for both terminals, turning the preamp off when moving the clips. It takes longer, but has a much better chance of getting clean data without accidental shorts.
BTW, I sympathize with the shaky hands, I have that too.
Offline Krishk
Reply #5 on: October 20, 2019, 05:16:22 PM
That's a really good idea I'll definitely try that. Do you think I damaged my amp in anyway with the previous sparking? I rechecked the resistances and they all came back normal again.
Reply #6 on: October 20, 2019, 05:33:25 PM
Maybe, maybe not. I'm not the Crack expert  :^)  But the only way to know for sure is to do the resistance checks (which you did) and then do the voltage checks.
Reply #7 on: October 20, 2019, 05:42:30 PM
As PJ said, you really can't tell until you do the voltages tests - that's real test for whether you have a working amplifier. There's more than a fair chance that the spark failed to cause any real damage - and if if something is damaged it will almost certainly be cheap to replace. The only pricey stuff in the amp is the transformer and the tubes, and i can't imagine a momentary spark doing them in.
Following up on PJ's recommendation, i suggest you get some alligator and mini-hook test leads. AmZon sells sets of test leads for under $15. I use mini-hooks almost exclusively. The hooks are small, so it would be very difficult to connect two difference points and cause a spark. And they grab onto the target terminal or wire really well. And in the occasional circumstance where they pop off the terminal you are measuring, an internal spring instantly retracts the hook: no accidental contacts.
cheers, Derek
Offline Krishk
Reply #8 on: October 20, 2019, 05:59:31 PM
Thanks a lot guys your help is greatly appreciated!
Reply #9 on: October 21, 2019, 05:13:05 AM
A spark at terminal 3 with your other probe at terminal 12 doesn't really say a lot about what the voltages might be.  Having that happen and then plugging in headphones and using the amp is not a wise course of action.
Reply #10 on: October 21, 2019, 08:48:01 AM
Take a piece of tape and wrap the metal tip of your red probe so that only the very end of it is exposed. That will help to avoid touching terminals you don't want to touch when you probe around in the circuit. Then redo your voltages measurements. They will most likely be fine.
Offline Krishk
Reply #11 on: October 21, 2019, 03:24:23 PM
Ok, so I got some hook leads and I tried to do the voltage testing again but the tube leds weren't lighting up however they were lighting up before. I checked all the soldering connections and everything was fine. Is it possible that I blew the fuse? If so how would I get a replacement?
Offline Krishk
Reply #12 on: October 21, 2019, 04:41:54 PM
Also, when I check to see which tube is glowing, only the 6080 is glowing where the 12AU78 does not.
Reply #13 on: October 21, 2019, 06:12:37 PM
Could you post the DC voltages you get on terminals 1 through 10?
If the 6080 lights up and the 12AU7 does not, the green twisted wiring going from the 8 pin socket to the 12AU7 may be loose at either end.  Do remember that the 12AU7 doesn't glow particularly brightly.
Offline Krishk
Reply #14 on: October 22, 2019, 12:48:28 PM
Hi so my voltage tests results are
Terminal 1: 170 Volts
Terminal 2: 190 volts
Terminal 3: 0 volts
Terminal 4: 190 volts
Terminal 5: 170 volts
Terminal 6: 0 volts
Terminal 7: 170 volts
Terminal 8: 0 volts
Terminal 9: 170 volts
Terminal 10: 0 volts
Just to reiterate, the leds and the 12au7 are no longer lighting up. However, yesterday before I sparked terminal 3 the leds and the 12au7 tuber were both lighting up.
Once again thanks for the help, I'm a bit of an amateur when it comes to electrical wiring so the help is greatly appreciated.
