Hi all,
I've discovered a strange issue recently. I'll explain my system first:
PC --> Schiit Gumby (Gen 5 USB) --> Drop THX AAA 789 amp (XLR & RCA) + Mainline (RCA) --> AudioQuest NightOwls & Focal Clears
With the setup above, I hear bad bass distortion from the Mainline, but not from the 789 amp. If I use a different DAC (e.g. Topping D50s) I have no troubles with the exact same track and the volume seems to be identical (i.e. I don't think the Gumby output is too hot).
I've tried:
- Different RCA cables
- Changing which RCA input sockets I use on the Mainline
- Disconnecting the second set of RCAs from the Gumby so only 1 SE output is used
At this point I'm stumped. With the D50s, the Mainline sounds as pure as ever, but with the Gumby it's sounding like tripe
Any suggestions?
