considerations in matching a DAC to the FPIII
bobster · 3987
Offline bobster
on: November 01, 2010, 01:44:15 PM
Hi
I'm am about to enter the world of computer audio but don't know enough about what parameters and values are important to make sure that the DAC that I get will work with the FPIII.
Can anyone help?
Thanks in advance.
Bob
Bob Musson
Seduction (extended), Foreplay, Paramours, Klipsch Heresys, Orcas, Crack plus HD 600s
Lovin the Bottlehead sound in Maryland
Reply #1 on: November 01, 2010, 01:48:08 PM
The input impedance of the Foreplay is relatively high so it will not be a troublesome load for any DAC. It has plenty of gain and it can be adjusted down if necessary. Really the only potential issue is that you will need a DAC with single ended RCA output jacks unless you want to use a card with a balanced output and an XLR to RCA interconnect.
Offline bobster
Reply #2 on: November 01, 2010, 03:07:52 PM
Thanks Doc.
I am going to see if I can start slow by trying an old G4 tower with a large external drive that I have and see where it goes from there.
Bob
Bob Musson
