Crack finish. Volts problems.
michael30 · 6119
Reply #15 on: November 11, 2019, 05:02:43 AM
The 0V at terminal 5 looks unlikely based on the other voltages, can you double check?
Offline michael30
Reply #16 on: November 11, 2019, 08:51:00 AM
after 30 min run.
terminals:
1)86.8
2)174
3)0
4)174
5)89.5
6)0
7)110.4
8)0
9)112.5
10)0
Yesterday i checked it with 235v.. now im at my brother house and i get around 223v from the wall.
Also I think can hear diff in volume between left and right ( left +1 -2).  not sure yet.
« Last Edit: November 11, 2019, 09:12:48 AM by michael30 »
Reply #17 on: November 11, 2019, 09:47:44 AM
Those are working voltages.  You can check the Crack FAQ stickied on this board regarding channel imbalance at low levels on the volume pot.  It's not abnormal and there's an easy modification to fix that.
Offline michael30
Reply #18 on: November 13, 2019, 01:44:45 PM
Hey Paul .
Just wandering... I wasn’t able to touch the chassis because it gets really hot, is that normal for the crack ? I only using 1/10 of the volume right now.. after 2 min I can’t touch it.
Reply #19 on: November 13, 2019, 02:39:48 PM
If the voltages in your amp are normal, then the temperature of the top plate is normal (provided you have also installed the rubber feet).
A stock Crack will produce some extra heat in the top plate around where the 3K/10W resistors are and the Speedballed Crack will produce slightly more heat overall under the plate, but less localized.
Offline michael30
Reply #20 on: November 16, 2019, 06:35:23 AM
Hey there.
After some time with the crack I have a new problem .
Some static noises and chuckles that comes and go...
I tried replace rca + all cables, still there come and go.. also some really low background noise that always there but noting harmful. But the static and chuckle really annoying , what it may be ?
First hours used was dead silent .
Ty Michael .
Reply #21 on: November 16, 2019, 11:12:20 AM
This could be an issue of solder joints or potentially interference from nearby electronics.  Are you using your computer as a source with the Crack?
Offline michael30
Reply #22 on: November 18, 2019, 09:28:49 AM
Computer/iPhone
But I did unplug all, left it only connected with my headphones and it didn’t stop.
For now it stopped .
I will update if it will come back . Also I will upload all my solders ..and re solder any points you will tell me.
Thanks again 🙏🏻
Michael.
Offline michael30
Reply #23 on: November 21, 2019, 06:36:51 AM
Hey.
here is the photos. if something else needed i will update as soon as i see.
https://drive.google.com/open?id=1AIkd22uIUl4odWHvNJ6TgT_yk-UfVJlj
also i swap the 12au7 to cbs jhy 5814a from 10/1960 , for now looks like those chuckles and noises gone.
anyway i would like to fix any bad soldering.
Ty Michael
Reply #24 on: November 21, 2019, 07:05:39 AM
I've found over the years that a lot of times swapping tubes will move solder joints that aren't 100%, which can make it look like an issue is tube related, but it comes back at a later time anyway.
You can also try this mod, which will help with external interference:
Reply #25 on: November 21, 2019, 07:17:15 AM
Hey.
here is the photos. ...
Hi Michael - you should delete your posting of the Crack manual - I don't think BH treats it as public domain.
cheers, Derek
Offline michael30
Reply #26 on: November 21, 2019, 07:25:29 AM
cheers, Derek
My mistake :-[,
fixed.
thanks Michael
Reply #27 on: November 21, 2019, 10:20:40 AM
Yes, whenever it gets posted, we get lots of e-mails for "replacement" power transformers ;)
Reply #28 on: November 21, 2019, 12:09:14 PM
I'd sell them for $225 with the option to upgrade to the full base kit for just an additional $90.   ;D
cheers, Derek
Offline michael30
Reply #29 on: November 22, 2019, 08:09:24 AM
I have sent you an email asking for the speedball guide , . so it’s me. ::)
And from your answer i understand that all the soldering looks good.
