Speedball upgrade fail - please help
vincentquy · 5104
Reply #30 on: December 06, 2019, 05:41:43 AM
Those caps feed both channels, so you won't get one low channel if there's an issue with that cpa.  That one is a little domed out at the top, what's your incoming AC line voltage and which range have you used when building the Crack?  That cap sees the lowest voltage and the least ripple current compared to the other 3, so it would be a bit strange to see something like that.
