Stereomour Oops
Drugolf · 6211
Offline Drugolf
Reply #30 on: January 02, 2020, 07:29:29 AM
In removing one of the caps on the PT-6 board I damaged the trace pretty bad.  It will either need to be repaired or the board replaced.  I emailed Eileen to see about the availability of a replacement board.
Reply #31 on: January 02, 2020, 07:33:10 AM
Those might have ended up with me, I'll have a look in my stash.
Offline Drugolf
Reply #32 on: January 02, 2020, 01:44:03 PM
Thanks Paul.  Eileen responded too that you would be the one likely to know if there are any still available at this point.  She is sending me a up grade power cord I purchased so I thought it made sense to see if you still had a board to include in the shipment.
BTW, I tested the 2A3 tubes on a Hickok 800A tester.  no shorts and passed mutual conductance wit numbers that reflect new and the same.
Reply #33 on: January 02, 2020, 01:58:17 PM
I did find a small stack of Stereomour I power supply boards, but I don't think I'll be at the office for a week or so.  If you contact me at pb(at)bottlehead(dot)com, we can see if the USPS letter sorting machines can handle a PC board in a paper envelope ;)
Offline Drugolf
Reply #34 on: January 02, 2020, 03:02:26 PM
Perfect!  Thanks Paul.
