I’ve built the original Stereomour and the Kaiju....
ebag4 · 1946
Offline ebag4
And I have determined my favorite of the two is the 2A3, as long as I am driving copacetic speakers.  My questions is are:
The Kaiju is a superior piece of kit vs the original Stereomour (no slouch in its own right)!
Will the Kaiju ever be moddable for the 2A3 tube?
Is the Stereomour II a significant improvement over the original?
Best,
Ed
GO CARDS!!!
Offline Alonzo
Reply #1 on: January 18, 2020, 06:38:29 PM
Yes,
Only to the Stereomour I vs Stereomour II.  :)  The other part is for the experts but with the new monoblock I would venture no.
Now for the I vs II, my one(s) are heavily modified and they are still a step below the II in background. Everything else will depend on your speakers and mods.
Alonzo
Reply #2 on: January 18, 2020, 08:05:31 PM
Of course research continues, but at present this is the situation:
Kaiju is impractical to modify for 2A3s, primarily because it does not have suitable power transformer windings - both filament and plate supplies are at too high a voltage.
Stereomour II in stock form is only slightly different from the original. They still use 12AT7s, to maintain enough gain for use without a separate preamp. But the quiescent current is increased a bit, and the bias resistor is unbypassed, both of which help. Other than that, it differs from the original mostly in its ability to be upgraded:
* The switched attenuator  as used in BeePre and Mainline can replace the volume/balance controls
* The drivers can be upgraded to have shunt-regulated power, as used in Kaiju. ()
* There is a DC filament upgrade, if you have extremely efficient speakers
The ultimate Bottlehead 2A3 is, of course, the new MonAmour, which uses much of the Kaiju technology, including shunt-regulated 5670 drivers and the much larger Kaiju output transformer/plate choke.
Offline ebag4
Reply #3 on: January 19, 2020, 09:55:34 AM
Thanks for that Paul, I haven’t been around much of late, so I was unaware of the new 2A3 amp.  Perhaps it is time for a new build   ;D.  Time for some research.
Best,
Ed
GO CARDS!!!
