Feedback through headphones, looking for advice [resolved]
pierrot · 2067
Offline pierrot
Hi All,
I'm having a bit of difficulty troubleshooting my crack build and i'm looking for advice on how to fix my issue.
I'm mainly getting the rubbing sound feedback every now and then and I haven't been able to fix it. I think it started when I installed the speed ball 1.1 OTL upgrade.
using leadless solder and a soldering iron that goes to 480 degrees C.
So far I've been going through the joints and reheated all of the ones that looked a bit dodgy. Probably missed some though!
thanks!
edit: the last board had one of the wires fall off when I was moving it to take a picture, going to resolder it on later.
« Last Edit: February 26, 2020, 04:34:27 AM by Paul Birkeland »
Reply #1 on: February 16, 2020, 04:46:01 PM
I would get some 60/40 solder with lead and touch up every single joint in the amp.
This is what I do for factory repairs that come in with lead free solder.
Offline pierrot
Reply #2 on: February 16, 2020, 06:37:09 PM
Thanks, I'll do that and report back.
Offline pierrot
Reply #3 on: February 23, 2020, 11:05:58 PM
Alrighty,
I've basically added a dab or redid the solder joints that had too much solder after a dab with 60/40 lead solder.
Unfortunately I still have an intermittent crackle/squeel in both sides
All the LEDs light up and both the tubes light up.
Please advise
« Last Edit: February 23, 2020, 11:21:54 PM by pierrot »
Reply #4 on: February 24, 2020, 05:01:32 AM
Can you repost some new photos? Did you use any separate flux during any portion of this soldering?
Offline pierrot
Reply #5 on: February 25, 2020, 08:48:36 PM
I didn't use any additional flux, but after leaving the amp turned on for the last 48 hours the fuzzy noise has mostly gone away.
Maybe it just needed to burn in (:
Thanks for the assistance Paul! I'll come back if I experience any significant background noise.
