Thanks and question for phono stage match
Dynakitbuilder · 1802
Offline Dynakitbuilder
on: February 19, 2020, 08:25:00 AM
Just finished the SEX 3.0 kit with nary a screw-up!  Pretty amazing for these 74 year old eyes and hands.  Thanks for the help and encouragement. Now looking to build a phono pre-amp.  What will match up with this the SEX ?  My phono cart is a ClearAudio Performer V2 MM.  Thanks again.
Reply #1 on: February 19, 2020, 10:10:37 AM
Nominal output of the Performer (3.3mV) is a bit lower than the standard 5mV. That is at the lower end of the recommended output range for the Reduction phono preamp. If you decide to go with the Reduction the Integration constant current source upgrade will be mandatory to get the gain optimized for that cart, as it gives the Reduction about 4dB additional gain (40dB total). The Eros phono preamp with its 10dB more gain (50dB total) will be an easy match to that cartridge.
The sonic quality of the S.E.X. amp is good enough to show the "family sound" of these two phono preamps and also good enough to reveal the slight advantage in resolution and bandwidth that the Eros has.
