Bottlehead Kits
Legacy Kit Products
Quicksand
Jump Starting the Quicksand
gnnett
19588
gnnett
Jr. Member
February 28, 2020, 12:55:10 PM
Well I am about to put a second board into my Quicksand and was going to ditch the C cell batteries, and was thinking of two of these?
https://www.dicksmith.com.au/da/buy/certa-12000mah-portable-jump-starter/?utm_source=MailList&utm_medium=email&utm_campaign=20200229_EDM_1_DS_AU_PHNA_HPHN_POWERBANKS
Can I run 2 boards off the same power supply, that would consist of two of these in series?
Regards
Grant
Paul Birkeland
Global Moderator
Hero Member
Re: Jump Starting the Quicksand
Reply #1 on:
February 28, 2020, 01:16:55 PM
I can't remember if call that caps in the kit are rated for that much voltage. You could just use one of those instead if power isn't a huge issue.
gnnett
Jr. Member
Reply #2 on:
February 28, 2020, 05:48:11 PM
Ah yes good point. I was originally looking at the 18V cordless drill batteries, which might be easier.
Cheers
Grant
Paul Birkeland
Global Moderator
Hero Member
Reply #3 on:
February 28, 2020, 06:35:33 PM
The battery life of the C cell batteries in the Quicksand can be enormous, so it's tough to rationalize this. The Quickie, on the other hand, could definitely benefit from something like this.
gnnett
Jr. Member
Reply #4 on:
February 28, 2020, 09:20:54 PM
Well yes it is quite good, but maybe if you had collected as many batteries as I have, for safe disposal, you might also be looking to rationalise.
The thought of running two boards and using even more C-Cells is my motivation.
Cheers
Grant
Karl5150
Sr. Member
Reply #5 on:
May 11, 2020, 06:37:06 AM
+1 on the 18v tool battery. I've been running my Quicksand on one for 5 years (recharging/swapping when necessary of course). I documented the build here back in '15. It now resides in the garage and keeps me company while I work on other projects.
Bottlehead Kits
Legacy Kit Products
Quicksand
