MonAmour troubleshooting - no music [resolved]
keithp · 26119
Reply #15 on: March 10, 2020, 04:25:24 AM
Hey Keith - A number of the solder joints have a crystalline appearance and may be cold joints -- see particularly the center third of the board, and some on the 8-pin socket.  The shielded red and black pair and the resistor terminations on the socket look like they need to be crimped and resoldered.
Rather than trying to guess which one is the culprit, I'd just reheat all of them and only be satisfied when the resulting joint is smooth. Determining this on small joints can be a challenge. I use magnifier glasses to see what I'm doing, and can't/won't solder without them.
cheers and good luck, Derek
Reply #16 on: March 10, 2020, 05:16:56 AM
Yes, pins 1 and 9 on the 9 pin socket look like they could use a little extra solder.
Offline keithp
Reply #17 on: March 10, 2020, 05:51:08 AM
It works. Sounds great!!!!!! Thank you immeasurably.
Reply #18 on: March 10, 2020, 06:19:42 AM
on the 8-pin socket
on the 9 pin socket
Sheesh. I knew my math was pretty rusty and that I need to brush up on trig, algebra and calc. I've now added "how to count to 10" to the top of the list. I still have all 12 fingers (I just counted them), so this shouldn't be a problem.  ;D
