Foreplay III Extended Voltage Check at Terminal 12
Comfortably Dumb · 3519
Offline Comfortably Dumb
on: November 03, 2010, 12:38:05 PM
I just completed my FPIII Extended upgrade and all voltages and resistances are within tolerance, however I noticied that the voltage at terminal 12 starts out around 180V and only reduces to 150V after a few minutes of turning the FPIII on.
I have not hooked up the FPIII yet to see if plays, as my amp is at the amp doctor right now getting a check up.
Is the terminal 12 voltage of 180V at startup indicative of anything?
Thanks.
Reply #1 on: November 03, 2010, 01:12:03 PM
No problem. The hybrid shunt regulator does not kick in until the tube warms up; until then the voltage is high.
Reply #2 on: November 03, 2010, 01:23:41 PM
Thanks.
