Transformer terminals read 9 VAC rather than the "about 9.7 VAC" called for
PaulG · 1969
Offline PaulG
Building a 5 year old Eros kit finally.
On page 42 of the manual the first item is to check the voltage between transformer terminals 4 and 5.  Mine measures 9.0 VAC rather than the "about 9.7VAC" called for in the manual.
The Bottlehead transformer (PT5) has a label that calls for 9VAC at Terminal 5 which is what mine measures.
Is 9.0 VAC close enough?  Have I done something wrong?
Paul Grisanti
Gentleman of a certain age
built Heathkits in the late 1960's
built two Audio by VanAlstine kits in 1990
Is your powerline voltage low? Does your meter have fresh batteries? I think those would be the likeliest causes.
Offline PaulG
Thank you for the response.  Batteries in the GB meter are new as of 2 weeks ago.  I have access to a Klein multimeter which I will try to see if they agree and then check the line voltage.
Paul Grisanti
Offline PaulG
Great call on the multi meter.  The Klein reads 9.69 volts so it looks like I can go forward.
Thank you for the guidance!
Paul Grisanti
