Isolation transformer advice
Neuronal · 5986
Offline Neuronal
    • Datta Lab Website
on: April 02, 2020, 10:38:33 AM
I'm a near-total newbie, and in reading the intro material to my kit it recommends an isolation transformer for safety. From reading online, the standard Tripp-Lite isolation transformers are used for de-noising, but don't actually provide safety if you are working on your rig hooked up to power. Is that right? Can I use something like this instead? - https://www.jameco.com/z/ITR300-Power-Transformer-Isolation-120VAC-120VAC-300VA_181315.html
thanks so much in advance for advice, and my apologies if this answer is obvious.
Bob D
Rega P2, Cosecant DAC, Reduction, EFP III, Paramount V1.0 + soft start, Omega CAMs + DeepHemp 8s
Reply #1 on: April 02, 2020, 12:29:31 PM
You'll be OK without one.  That recommendation really comes from the time before we used power entry modules with integrated fuse holders.  Now that we do, you'll blow the fuse before you get much more than a rigorous tingle if you touch the mains.  If you happen to have a GFCI outlet, it will trip at about the same time that you realize you've touched the mains.  That's what I would recommend using for wherever you're building the kit.  You can get a plug in GFCI for convenience if you don't want to replace an outlet or don't otherwise have one handy.
Offline Thermioniclife
Reply #2 on: April 02, 2020, 01:12:58 PM
Hello,
I use a Tripp Lite isolation trans my self and can tell you that it is not truly isolated in the fact that on the secondary side the neutral is also connected to the chassis. This is however easily corrected by opening up the unit and you will see that on one side the white neutral wire has a green wire spliced to it and is connected to a chassis ground stud. simply remove the green wire from that stud and insulate it with heat shrink and now you will be fully isolated from ground on the output.
This helps keep the sphincter pucker factor down when working on sketchy equipment.
