dimensions under plate
arveedub · 3633
Offline arveedub
on: November 06, 2010, 04:51:17 AM
What clearance is generally required between the top plate & the bottom of the base of a sex amp with the c4s expansion?
Offline arveedub
Reply #1 on: November 06, 2010, 04:52:56 AM
Didn't notice that I was in the wrong forum till I posted. Sorry.
Reply #2 on: November 06, 2010, 02:54:50 PM
I'm building my s.e.x. amp in a base that is 2-1/2" tall, so a little less for the inside clearance.  is that what you want to know?  All the stock BH bases are 3.5" tall, not including feet.
Offline JC
Reply #3 on: November 06, 2010, 04:04:45 PM
On the S.E.X., I think you'll find that it is the plate chokes, which mount on the underside, which will dictate the minimum depth for the base.  At least I don't recall anything hanging any lower, C4S included.  IIRC, the plate chokes are just shy of 1-3/4" deep, so I believe a couple of inches of depth will do as a bare minimum.
Of course, this assumes a stock build; swap out a bunch of caps for gigantic film types, and all bets are off.  Same for Magnequest plate chokes---I have no idea how far they may hang down.
Jim C.
Offline arveedub
Reply #4 on: November 07, 2010, 01:33:55 PM
Thanks, guys
I'm putting together a small living room system & am thinking about installing a dac in the same enclosure as the amp. I don't want the base to get too high so building the case a bit longer to accomodate the dac may be my best option.
Reply #5 on: November 07, 2010, 02:00:58 PM
Things could get a bit crowded in there and in terms of electrical noise, temperature and such, inside may not be the best place for a dac.
One thing I considered doing was mounting my HRT musicstreamer II + on the back of the s.e.x. -- it's small enough and I believe that it should work ok.  A really decent dac for the money too.
