First Build: Bad Tube
gabriel · 1828
Offline gabriel
on: April 13, 2020, 03:54:55 PM
I just completed construction of the Eros 2 and am wondering whether I have a bad tube and/or broke it.
Just after completing I listened to some music and it sounded wonderful at reasonable volumes.  However at semi-loud volume with nothing playing there was a fluttering in the left channel (helicopter sound), and a pretty reasonable buzz in the other channel.
Today I went through the wiring again and discovered some untrimmed wires touching the metal chassis.  I trimmed those, and there's much less noise and buzzing only at even higher volumes.  However one channel is now VERY quiet.  When I swap the EF86 tubes, the quiet channel swaps.  The tube which was generating the helicopter sound is now the very quiet tube.
Did I kill the tube?  Is the tube dead / the problem do you think?  Thanks for any help.
edit:
I just redid my resistance and voltage checks.  They were perfect immediately after completing the build.  Now the voltage checks are not.
IA,   IB 210-230V --> 215.2, 214.5
OA,   OB 155-185V --> 168.5, 145.0
OC,   OD  95-100V -->  95.3, 114.0
OkA, OkB  95-105V -->  96.7, 113.8
OkC, OkD   0.7-2V -->  1.28, 0.007
Do you think these measurements indicate a failed tube?
« Last Edit: April 13, 2020, 04:39:28 PM by gabriel »
Reply #1 on: April 14, 2020, 04:17:05 AM
The OKC/OKD voltage follows an EF86?
If so then yes, it's possible that one of those leads touching the chassis exhausted the EF86.  I just wrapped up an Eros 1 repair last week that had a similar issue that destroyed a brand new EF86 in the process.
Offline gabriel
Reply #2 on: April 14, 2020, 04:54:18 PM
Thanks Paul.  Those voltages do in fact follow the "bad" EF86.  Looks like I killed a tube.
Reply #3 on: April 14, 2020, 05:04:42 PM
Oh yeah, that tube is just totally refusing to conduct!
