Voltage Check High, Terminals 2 and 4
Bullpride · 1990
Offline Bullpride
on: May 13, 2020, 08:04:02 AM
Voltage check on terminals 2 and 4 are reading 212 instead of the recommended 170.  This is outside the 10%.  Everything else reads almost dead on.
Do I have an issue or am I good to go?
« Last Edit: May 13, 2020, 08:10:09 AM by Bullpride »
Reply #1 on: May 13, 2020, 08:50:00 AM
What is your AC line voltage?
Offline Bullpride
Reply #2 on: May 13, 2020, 08:57:06 AM
I am in the US.  120v ( not measured, but I can get a measurement).
Reply #3 on: May 13, 2020, 09:01:33 AM
Please do measure.  This should have been part of the build process.
Offline Bullpride
Reply #4 on: May 13, 2020, 09:26:38 AM
Sorry for the misunderstanding.
I did previously check and have checked again.  The powerline AC voltage N and L on the IEC is 122.6.
Well dammit I follow the wrong directions.
I followed the <115 instead of
IF your voltage is GREATER than 115V AC and
LESS than 130V AC
I will make the adjustment, moving the red wires to Terminal 15 instead of 14.
« Last Edit: May 13, 2020, 09:50:41 AM by Bullpride »
Offline Bullpride
Reply #5 on: May 13, 2020, 10:06:02 AM
Moving the red wire to the correct terminal dropped the voltage on 2 and 4 to 190.
Reply #6 on: May 13, 2020, 12:08:38 PM
No harm done there, your tubes will thank you in the long run.
Offline Bullpride
Reply #7 on: May 14, 2020, 03:00:52 AM
So on a related note.  When Stay At Home ends and I decide to take my crack to work, do I need to retest the power line voltage and move wires if necessary?
Reply #8 on: May 14, 2020, 05:53:26 AM
I think you'll find that most outlets in a 120V area are 120V.
If your office is in a really, really old building with a really old power service, the voltage could be down around 110V.  It certainly doesn't hurt to check.
