Integration Mod - Voltage test
Vili · 14614
Offline Vili
on: May 25, 2020, 05:02:49 PM
Reading DC voltage after second round of double check gives some erroneous values.
Voltage after 'Shunt Regulator Board' addition read slightly higher than 120VDC but was within ±10%.
After integration of C4S is where it gets out of bed,
Reading on terminal 2 was 101 VDC.
18, 26, and 31 were all within 2% of 74.4 VDC.
Only thing I can think of was after completion and testing of the default build, a few of the voltages were a little high, but only on one side of the assembly.
This didn't seem to effect balance between right and left channels at all, nor did it supply a distinctive difference in sound quality while playing (no noticeable hum)
Reply #1 on: May 25, 2020, 07:32:04 PM
Are all the LEDs lit up on the 9 pin sockets?
There are two possibilities:
1.  The center leg of the MJE350 where you're getting 101V isn't well soldered.
2.  There's a loose connection in your build that you've moved and now you've lost one stage.
Offline Vili
Reply #2 on: May 25, 2020, 07:59:37 PM
All LED's light up, but delayed and light only when the tube is fully illuminated.
I'll check the connection on the MJE350 and soldered/desoldered joints dealing with the integration addition.
I'll provide more info tomorrow afternoon.
Reply #3 on: May 25, 2020, 08:02:00 PM
In that case I'd also post some photos of your installation if possible.
Offline Vili
Reply #4 on: May 26, 2020, 02:35:18 PM
Sorry for the many mods, was having some issues with file upload.
Please forgive terrible soldering, I'm really trying to get better. Honestly half the reason I picked this particular model was to get better practice.
« Last Edit: May 26, 2020, 02:38:43 PM by Vili »
Offline Vili
Reply #5 on: May 26, 2020, 02:42:14 PM
Last one.
Also, did a check on the thru holes for the MJ350's to the pins of the MJ350's (testing solder joint) and for the problem side, was getting full continuity.
« Last Edit: May 26, 2020, 02:48:32 PM by Vili »
Reply #6 on: May 26, 2020, 03:38:21 PM
Well, I don't see anything super obvious.  You can swap the boards to see if that voltage moves around.  If it does, then you need to reflow all the joints on the side of the board that is providing that high voltage.  If the high voltage terminal does not move, I would reflow every joint on that side of the amp, then try again.
Offline Vili
Reply #7 on: May 26, 2020, 04:24:52 PM
Ok, so second round of testing, with both boards swapped.
2-   103.1 / 101.1
18-  75.1  / 74.1
26-   74.8 / 74.2
31-   73.5 / 73.2
First # is the initial pull, second is after lights were illuminated.
Note: The LED's are rather faint, they are upside down but not as bright as the other set of LED's on the power shunt.
Offline Vili
Reply #8 on: May 26, 2020, 05:43:28 PM
So went back and checked all solder locations feeding into that side, no missing or disconnected joints.
Are there any voltage or resistance values that I could read with a multi-meter that would help provide some sleuthing as to the problem source?
Reply #9 on: May 26, 2020, 06:46:33 PM
Also swap the tubes, just to be double sure.
Offline Vili
Reply #10 on: May 26, 2020, 06:56:50 PM
OK! Wasn't super expecting these results, but here goes:
2 - 73.6VDC
18 - 100.8 VDC
26 - 100.6 VDC
31 - 88 VDC
Could it be the tubes need contact cleaner???
Reply #11 on: May 26, 2020, 07:12:19 PM
I think you have more than one loose connection.
Offline Vili
Reply #12 on: May 27, 2020, 03:37:22 AM
I'm at a loss, I've checked the system several times for discontinuities from the post to the components on the C4's.
Would it be worth it at this point to go back a stage and re-test from the power-shunt portion of the mod?
Reply #13 on: May 27, 2020, 05:49:50 AM
You have loose connections on the tube sockets or terminal strips by the tube sockets.
You should reflow every solder joint in that section of the amp.
