Bottlehead Kits
Crack
Threads on Ground Screw messed up
jamesondrums
363
jamesondrums
Jr. Member
May 28, 2020, 02:39:16 PM
The ground screw that I got unfortunately will not thread. Is there a specific material that the screw has to be? I will get a replacement at Home Depot if possible.
Paul Birkeland
Global Moderator
Hero Member
Re: Threads on Ground Screw messed up
Reply #1 on:
May 28, 2020, 02:40:44 PM
Steel is a nice idea. Home Depot should have a zinc plated 8-32 screw that will work well.
Doc B.
Administrator
Hero Member
Reply #2 on:
May 29, 2020, 06:26:42 AM
Are you sure you used the 8-32x3/8 screw supplied, and not the 8-32 self tapping screw? They look similar and the self tapping screw does not want to screw into a nut easily.
jamesondrums
Jr. Member
Reply #3 on:
May 30, 2020, 03:53:46 AM
Yeah I triple checked that. It was just a small defect in the threads that completely stopped it from letting it thread into the nut.
Bottlehead Kits
Crack
