Voltage problems
jamesondrums · 3287
Offline jamesondrums
Reply #15 on: May 29, 2020, 07:48:24 AM
You're 100% correct. I'll fix it and get write back shortly.
Reply #16 on: May 29, 2020, 07:59:28 AM
Switched it, when I first plugged it in it read 1V, then it went down to .89V then .77V DC
Reply #17 on: May 29, 2020, 07:59:51 AM
And also still no LED
Reply #18 on: May 29, 2020, 08:28:20 AM
Gosh I'm sorry, I had two backwards. Fixed that and it's sitting right at .4mV, still no LED
Reply #19 on: May 29, 2020, 09:24:33 AM
A new overhead pic of the transformer and surrounding terminals with a clear view of the diodes might help.
Reply #20 on: May 29, 2020, 10:04:59 AM
Forgive the messyness, I don't have a way to remove solder at the moment so soldering those diodes back on was a struggle and a half
Reply #21 on: May 29, 2020, 11:57:47 AM
I would recheck the AC voltage again between 18 and 19, just to be sure that's still OK.  If you have ~160V AC at 18 and 19, but 0V DC at 20 and 21, then it's possible that your diodes didn't survive the backwards installation and will need to be replaced.
(Also the LEDs will not light up unless the high voltage power supply works)
Reply #22 on: May 29, 2020, 12:39:11 PM
Well, I just tried to check but then noticed I wasn't getting any reading because the fuse blew, so not 100% sure what happened there. I'll get replacement parts and repost once it's done. Thanks for the help.
