Power Tube "clinks" once hot
mtheshark90 · 1600
Offline mtheshark90
on: June 06, 2020, 04:39:29 AM
I've been tube rolling lately with some different 6080's and 12AU7's, and came across a weird issue I haven't seen before. My Tung-Sol 6080, after warming up for a couple of minutes, will start to make clinking sounds that come from the physical tube itself. The best way to describe it is -- it's like the metallic clinking you hear if you warm a pan up on the stove.
I'm not sure if this is actually a problem or not, or if it means that the expanding metal may cause the tube to spontaneoulsy break on me. I just found it be quite bizarre. If I wear the headphones while it makes this clink sound, I can hear it resonate into the headphones as well. Should I get this thing replaced?
« Last Edit: June 06, 2020, 04:45:21 AM by mtheshark90 »
Reply #1 on: June 06, 2020, 04:49:35 AM
That is the sound of glass getting hot/cooling off and it isn't anything to worry about.
Offline mtheshark90
Reply #2 on: June 06, 2020, 04:52:36 AM
Thanks Paul! That's all I needed to hear. Was worried the tube would crack or something. Take care!
