Caps upgrade
Alby0521 · 22359
Offline Larpy
Reply #15 on: June 20, 2020, 11:57:56 AM
Here's a question: if a cathode bypass capacitor is used to block the AC signal from going to ground (which is my admittedly limited understanding of why they're used), why would changing from an electrolytic to a poly cap make a sonic difference?  The musical signal doesn't actually pass through a cathode bypass cap, right?
Larry
Reply #16 on: June 20, 2020, 12:25:52 PM
Capacitors are a (relatively) short circuit to AC but do not pass DC current to ground.
Offline Alby0521
Reply #17 on: June 22, 2020, 07:22:55 PM
Ordered the Kaiju yesterday, ordered the 100uf caps today:)
I’ll be building it stock, than adding caps in different times. I’ll report back in about 1 or 2 months.
Best
AB
Reply #18 on: June 23, 2020, 04:19:39 AM
Thanks for your order!
Offline currly30
Reply #19 on: February 18, 2023, 09:37:32 PM
They fit.
I know this is an old topic but is it even possible to install the DC filament with those massive capacitors installed?
Offline Larpy
Reply #20 on: February 19, 2023, 09:08:14 AM
Worked for me.
Larry
Offline currly30
Reply #21 on: February 19, 2023, 12:30:15 PM
Nice, good to know.
