Paramount 300B hum balance adjustment
Anton · 32810
Offline Anton
on: June 28, 2020, 09:23:24 AM
Hello,
I have Paramount 300B monoblocks I built back in 2010 and currently use with Sophia Electric Princess 300B Mesh Plate tubes.
Recently I decided to check my hum balance, as per page 64 of the manual. The manual says the reading should be 0.8 - 2.0 mV - but I couldn't get mine below 2.5 - 3.0 mV.  Should this be a concern and what can I do to fix it?   I am using these 300B tubes since 2011 - is this time to change them?
Thank you
Eros phono / Foreplay III extended upgrade / Paramount 300B/ S.E.X. 2.1 impedance switch upgrade
Reply #1 on: June 28, 2020, 10:42:19 AM
Do you still have the stock tubes?  You could certainly pop them in and give them a shot.
Offline Anton
Reply #2 on: June 28, 2020, 11:27:10 AM
Hi Paul,
Thanks. Yes - I still have stock EH 300B tubes. I actually tried to pop them in, but the reading is still around the same range 2.9 - 3.9 mV.
So - I guess this is not a tube issue then?
Reply #3 on: June 28, 2020, 12:51:24 PM
Do you get the same reading with no 9 pin tube installed?
What meter are you using to measure the hum voltage?  Is there a load on the amp? (A speaker connected)
Offline Anton
Reply #4 on: June 29, 2020, 01:05:30 AM
Paul,
I have the same readings without 9 pin tube (12AT7EH) installed.
The meter I am using is "Fluke 115 True RMS Multimeter" - I set it to AC millivolt scale.
During the hum voltage measurement, I don't have a load on the amp - a speaker is not connected.
Reply #5 on: June 29, 2020, 05:03:14 AM
Hum measurements at the output are taken with a load on the amp. Hook up your speakers and take the measurement again. That will give you a reading that corresponds to the way our hum spec is measured.
Offline Anton
Reply #6 on: June 29, 2020, 06:00:15 AM
Hello Doc,
Thank you very much.
I went ahead and hooked up a speaker to my Paramount and re-check the measurement. It still reads in the same range 3 - 4 mV.
It doesn't stay steady, but rather changing constantly in that range.
The speakers I am using are Cain&Cain Abby with a sensitivity of 95 dB and a nominal impedance of 8 ohms.
Reply #7 on: June 29, 2020, 06:12:35 AM
Do you actually hear any hum?  How fresh are the batteries in the meter?
Offline Adrian
Reply #8 on: June 30, 2020, 04:15:40 AM
My Paramount manual does not mention the need to connect the speakers to the binding posts along with the meter leads when adjusting the Hum Balance.
I don't have the 300b Kaiju.  However, is this also recommended for adjustment on the Kaiju?
Just curious.
Adrian C.
Offline caffeinator
Reply #9 on: June 30, 2020, 04:28:17 AM
Make sure to do this test with the input shorted. I remember checking the hum balance on my Paramounts - a looooooong time ago - and it seemed high to me. Shorting the input brought that back in line with the nominal specs in the manual.
I keep meaning to get myself a set of RCA shorting plugs...one of those things one needs only once in a great while, though it's easy to MacGyver something on the spot.
Offline Anton
Reply #10 on: July 01, 2020, 02:54:06 AM
Paul,
Yes - I hear some hum from the speaker when connected to the paramount. Not very loud - you have to stand near the speaker to hear it. But still - it is louder, than when connected to my S.E.X. integrated amp.
I just changed the battery in the meter and re-took the measurements. it reads the same - I guess the battery was fine.
Also - I did short the input when taking the measurements.
« Last Edit: July 01, 2020, 04:29:08 AM by Anton »
Reply #11 on: July 01, 2020, 05:06:22 AM
Just to clarify, you don't need a speaker load to adjust the hum balance. In fact it might be easier to find the lowest hum level without a load, as the hum level will be higher without a load and it might be easier read the changes on your meter as you twist the balance pot looking for the low point. However you do need a speaker load on the output to determine a useful number for hum magnitude, as it will be lower than with no load. And that is the standard used for hum measurement.
Reply #12 on: July 01, 2020, 06:59:11 AM
Of course I also forgot to ask if you have the amp wired for 16 ohms, which will increase the hum voltage seen at the output.
Offline Adrian
Reply #13 on: July 02, 2020, 03:01:27 AM
Dan
Thanks for your great explanation on hum balance adjustment with and without a load on the amp.
Adrian C.
Offline Anton
Reply #14 on: July 02, 2020, 03:43:54 AM
Paul,
I think my Paramounts are wired for 8 ohm, just standard version.
