Checking voltages after pot change
oguinn · 1809
Offline oguinn
on: July 04, 2020, 09:54:26 AM
I dropped an Alps pot in earlier today. I am on very little sleep with the new baby so sorry for the dumb question  - will the Speedball voltage checks suffice or are there more I should check?
Jameson O'Guinn
Offline Thermioniclife
Reply #1 on: July 04, 2020, 10:17:58 AM
Let her Rip.
Offline oguinn
Reply #2 on: July 04, 2020, 10:19:22 AM
I’ll go run the tests when either the baby or my wife wakes up. Thanks, Lee
Jameson O'Guinn
Reply #3 on: July 04, 2020, 04:28:57 PM
Probably more useful to do the resistance checks...John
Offline oguinn
Reply #4 on: July 04, 2020, 05:27:00 PM
Some of the resistances change when you add the Speedball, right? It’s been a while since I did it. I guess it’s probably more important to check the resistances at the pot since that’s where things changed.
Jameson O'Guinn
Reply #5 on: July 04, 2020, 07:08:00 PM
Hey Jameson - Congrats on being a Dad!
Were it my amp. I'd just give it a listen. But maybe I'm a bit reckless. Never tried this, but I think the following would test whether the pot is installed and working properly: (1) with amp unplugged and off, turn the pot all the way up; (2) measure resistance between right channel (red +ve) rca input and red signal wire on the 9 pin socket (pin 7?) - you should see relatively little resistance; (3) turn pot all the way down -- the resistance should go way up (assuming it's a 100K pot, I'd expect the resistance to be about 100K); (4) repeat steps (1) to (3) for the left channel (white wires); and (5) check for ground continuity between either or both of the 0V blacks wires at the rca inputs and either/both of the center terminal of the 9 pin socket and/or the middle lug of the terminal strip adjacent to the 9 pin.
If all of that looks good, then give it a listen.
cheers, Derek
Reply #6 on: July 04, 2020, 07:18:10 PM
Or you just turn the thing on and see if it works.
Offline oguinn
Reply #7 on: July 04, 2020, 10:14:44 PM
I’ve read your posts long enough to never turn on an amp that’s had work done without at least testing voltages :)
And thanks, Derek!
« Last Edit: July 04, 2020, 10:16:22 PM by oguinn »
Jameson O'Guinn
