Can the old speedball be used on the Crack 1.1?
Jimb0 · 1723
Offline Jimb0
on: July 10, 2020, 07:27:03 AM
Are there any wiring differences other than the ones going to the Speedball that I need to change?
Reply #1 on: July 10, 2020, 07:28:04 AM
You could do that, sure.  An old Speedball will be old enough that I would throw away the LEDs and replace them.
Offline Jimb0
Reply #2 on: July 10, 2020, 07:52:55 AM
Thanks PB
Reply #3 on: July 10, 2020, 08:06:33 AM
In a pinch, you can bake the HLMP-6000s in your oven at a low temperature for 5-6 hours to get any moisture out.  You'd have to look up the temperature specs for doing that though.
