Zero bias
vetmed · 4018
Offline vetmed
on: July 29, 2020, 06:29:27 PM
Will an input transformer work in front of a tube with the tube's grid grounded? I am considering:    Input transformer- tube biased at 0 volts- IT- output tube-output transformer. The plate curves of the input tube look very promising at 0 grid volts. I suppose it will depend largely on the nature of the input transformer. Any input greatly appreciated :D
Robert Lees
Reply #1 on: July 29, 2020, 07:44:55 PM
Grid current will be a problem, it's very nonlinear around zero bias. That's why tubes are biased.
Some data sheets have graphs showing grid current - usually as dotted lines on the regular plate curves.
Reply #2 on: July 30, 2020, 04:37:50 AM
Typically for this kind of architecture you would use an interstage transformer before the zero biased tube so you can select the tube behind it to provide appropriate drive.
For a two stage single ended amp doing something like this, you'd need something like a 15K:150 transformer to properly attempt to do this, but grid current issues would likely make an input transformer unsuitable for this duty.  The large step-down ratio would probably cause gain issues as well.
Offline vetmed
Reply #3 on: August 01, 2020, 05:22:58 AM
Thanks for responding, seems likely that when grid current does flow then core saturation will occur, which probably doesn't sound very good ::)
Robert Lees
