Speedball voltage, B+ low on the big board [resolved]
rat3hat · 1342
Offline rat3hat
Hi. I have one voltage check outside of the target range  for the big board:
Targets from the manual:
OA  75-100V
OB  75-100V
G    0V
B+  170-195V
My voltage readings:
OA    90.7V
OB    77.4V
G      0V
B+    114.5V
B+ should be higher. It is probably the usual suspects (crappy joint somewhere), but I thought I'd ask where was likely.
Best,
Chris
« Last Edit: August 02, 2020, 09:28:12 AM by Paul Birkeland »
Reply #1 on: August 01, 2020, 08:21:19 AM
B+ connects back to terminals 2 and 4, as well as IA and IB on the big PC board.
How are the voltages on the small board?  Does B+ pop back up if you run the amp without the 6080?
Offline rat3hat
Reply #2 on: August 01, 2020, 08:38:34 AM
Small board Measurements
OA 75V
IA 120V
B-A/B 0V
IB 120V
OB 75V
It did pass checks after mounting small board earlier
Large board without 6080 B+ is 225V
Offline rat3hat
Reply #3 on: August 01, 2020, 08:41:53 AM
Also, perhaps the heat sink closer to the 6080 is hotter than the heat sink closer to the 12au7 socket. Not sure if this means anything.
Reply #4 on: August 01, 2020, 10:13:26 AM
Are the TIP50 transistors properly mounted?  Be sure B+ to the big board is not connected to terminal 2 or 4 by accident.
If all else fails, you can post photos of the build and we might be able to spot something.
Offline rat3hat
Reply #5 on: August 01, 2020, 11:24:10 PM
OK. My 15 y/o was sharp enough to point out that I was missing an LED on the big board at D2....  :o >:(
Once I put that in, it all seems to be measuring in range. On the big board OA, OB are measuring ~110V each. That is around 10% above the high - I am assuming that is OK - or is that just too high?
« Last Edit: August 02, 2020, 04:00:00 AM by rat3hat »
Reply #6 on: August 02, 2020, 06:13:52 AM
Yes, that's OK.
Offline rat3hat
Reply #7 on: August 02, 2020, 06:34:50 AM
Thank you, again - for being a patient and excellent guide. Great kit.
