Inductive or Non-Inductive Cathode Bias Resistor?
Guest · 1689
on: August 09, 2020, 02:49:43 PM
I am just putting together what will hopefully be the last Mouser order for the Kaiju rebuild.  And since I'm going "all out" I figure I'll get some nice Vishay 1%, highly temp stable 1K bias resistors for the 300Bs.  I've gotten into the habit of automatically choosing non-inductive wirewound resistors - figuring that inductance in a resistor is a nuisance best avoided.  But for a cathode bias resistor, where I want a constant current through the resistor to maintain a constant voltage drop, maybe inductive is the way to go?
Any thoughts on that?
cheers and thanks, Derek
Reply #1 on: August 09, 2020, 07:48:56 PM
Inductance in a resistor can be a big problem when you have high frequency signal passing through it and the inductance in the resistor makes the resistor appear to be a much higher impedance value at those high frequencies.  In a cathode biased 300B amp, the cathode resistor has a huge cap across it, so there's nearly no signal current passing through the resistor, so a little inductance isn't problematic.
Reply #2 on: August 10, 2020, 12:31:41 AM
Many thanks PB.  That makes sense. I forgot to take into account the role of the cathode resistor bypass cap in maintaining a relatively constant voltage bias.  So I think I'll just stick with non-inductive out of an abundance of caution.
