Power rating of the 0 ohm resistors?
Guest · 3740
on: August 10, 2020, 01:13:13 AM
What is the required power rating of the two 0R resistors? Less important question: are they used as fuses?
MTIA, Derek
Offline Adrian
Reply #1 on: August 10, 2020, 01:36:05 AM
IIRC 0 ohm resistors or "links" are used as short circuit jumpers of a sort.  Sometimes it is easier to install them than very short pieces of wire, especially in SMD applications.
All they have to do is handle the current in the design application. Current and voltage will determine the power rating  (P=I^2R).
Adrian C.
Reply #2 on: August 10, 2020, 01:52:16 AM
Thanks Adrian. I seem to recall reading something to the same effect somewhere on this forum. If that's the case, I'll just use wire.
Reply #3 on: August 10, 2020, 05:52:59 AM
I do find it funny that they have a power rating.  I suppose that's more about the size they are than anything else.
The teflon coated wire we provide is super nice, but it's also hard to strip the ends of a really short piece, so a 0 ohm resistor makes things much easier.
Reply #4 on: August 10, 2020, 06:36:45 AM
Cool. Thanks.
I deal with that by stripping the entire length of wire that I need, cut the removed teflon jacket to desired length, and slide back on. Being teflon, it slides on easily.
cheers, Derek
