Just got my Crack kit, tubes look used?
jivex5k · 3469
Offline jivex5k
on: August 12, 2020, 01:52:34 PM
So I just got my crack kit today. I opened up the bubble-wrapped tubes to check them out, they look used.
They both have blemishes all over, the logos are rubbed partially off. Some parts of the glass are silver looking?
Is this just normal and I'm ignorant about the world of vacuum tubes?
I sent an email to queen@bottlehead, figured I would ask here too.
Reply #1 on: August 12, 2020, 02:06:33 PM
Yes, we use old stock tubes and test them on a TV-10.  To my knowledge, there are no new production 6080s.  There are, however, tons of tubes that sat around in storage areas for decades that have a full service life ahead of them.
Offline jivex5k
Reply #2 on: August 12, 2020, 02:08:25 PM
Is there a way to clean them up?
Here's what they look like:
imgur.com/a/XaHoO7w
Reply #3 on: August 12, 2020, 02:25:37 PM
Those don't look particularly dirty.  You can clean the glass with Windex and a paper towel, but that may wipe the printing off.
Offline jivex5k
Reply #4 on: August 12, 2020, 02:28:39 PM
Okay thanks, I have no experience with this so I'll take your word. I'm really looking forward to building this thing, I put a cheap oscillscope together to pratice soldering beforehand.
Base is gluing overnight, and I'm researching finishes now. The miter joints were perfect.
Reply #5 on: August 12, 2020, 02:29:54 PM
Yeah, the guy we use for the wood bases has to have some kind of magical miter saw, I can never get mine that perfect!
Offline Natural Sound
Reply #6 on: August 12, 2020, 07:13:39 PM
imgur.com/a/XaHoO7w
You are lucky you got a 12AU7 Baldwin black plate. Those sound really nice.
Offline Raymond P.
Reply #7 on: August 12, 2020, 08:46:40 PM
The only cleaning you might want to do is use Deoxit contact cleaner on the pins using cotton swabs.
Raymond P.
Offline Joe Garfield
Reply #8 on: August 13, 2020, 03:44:14 AM
A good old tube is better than a crappy new tube. A lot of tubes are sold as “new old stock” but many are really just lightly used and meet “as new” testing/requirements.
Mine came with a pretty well used looking tube. I was  thinking I’d clean the glass and paint the metal sleeve with high temp paint. It’s not a special tube so I don’t care about the label. But then I got different tubes for better sound so that probably won’t happen :)
Joe Marri
Modi MB > Crack > HD650
Reply #9 on: August 13, 2020, 05:08:48 AM
Quote
And he has about 20 years of experience milling them for us.
Regarding the tubes, yes they are used. As others have said, there really aren't any new 6080/6AS7s. Even the Russian ones are most likely rebranded old stock. We test each one before we send it out to be sure they meet specification. Cosmetically they may show their age. People used to give me shopping bags and cardboard boxes full of 6080s before we came out with the Crack. Now after so many years of selling thousands of Crack kits they are still readily available one or two at a time, but it is getting more and more difficult for us to acquire the large quantities we need to supply kits. I spend time each day competing (yup probably with you guys) for tubes on ebay. Secret stashes of several hundred new old stock tubes are long gone. We know because we bought 'em and shipped them out in kits.
Offline oguinn
Reply #10 on: August 13, 2020, 05:23:24 AM
Sounds like it’s time for the Bottlehead DIY 6080 kit. It includes a blast furnace, some tungsten, and a heavy metal disposal bucket
Jameson O'Guinn
Offline jivex5k
Reply #11 on: August 18, 2020, 05:05:45 AM
Thanks for the feedback, my concerns have been completely eased.
I've been taking my time finishing the base, used a chestnut stain and finished with odie's oil. It looks very nice, not too dark, not too glossy.
I used hammered on black spraypaint for the face plate and bell which also came out looking very nice.
I went to start putting the kit together and realized I spray painted the wrong side of the plate. Whoops!
It's all sanded off now, other side has been painted and is drying. I'm going to put another coat on today and then let it dry for a few more before working on it.
Maybe I'll build that power cable in the meantime...
Reply #12 on: August 18, 2020, 05:30:08 AM
The hammer paint takes eons to cure, I would let it sit for at least two weeks before proceeding with the build.
Offline jivex5k
Reply #13 on: August 18, 2020, 05:57:44 AM
Will do, in no rush here.
Offline caffeinator
Reply #14 on: August 18, 2020, 06:48:37 AM
Watch out on recoat times for some spraypaints. I've had issues with recoating outside recommended times when using both Krylon and Rustoleum hammered finish (aka Hammerite) and not adhering strictly to the recoat times on the label instructions. I believe these have all been acrylic paints; some others, such as lacquers, may be more forgiving.
When following the label instructions, which were something like '...recoat within 15 minutes or after 10 days,' things went all right. The 15 minutes was good guidance, the 10 days was really more like two weeks or more, probably temperature/humidity dependent. Here in the northwest US, 15 minutes was really the only practical option as I never was able to outlast the longer recoat times. If one were to violate the recoat times, the paint tends to fisheye pretty consistently, usually necessitating sanding and starting over, but occasionally with kind of interesting results that are acceptable if not somewhat cool.
