Sudden distortion
C LaFong · 1528
Offline C LaFong
on: August 24, 2020, 04:25:06 PM
Crack went from sounding great to crap overnight.
The distortion is most noticeable with vocals, they sound almost like gargling if that makes sense.
Tubes or something else?
Reply #1 on: August 24, 2020, 04:31:53 PM
If it's both channels, it's unlikely to be a tube.   I would do a set of DC voltage checks just to be sure.
What you describe is how I would describe a bad solder joint.  If it's on both channels, that's how I would describe a bad solder joint on the ground buss.
Offline C LaFong
Reply #2 on: August 24, 2020, 04:52:26 PM
It is both channels. I will check the solder joints. Thanks.
