2nd set of inputs on crack?
martinman · 1695
Offline martinman
on: August 28, 2020, 03:10:51 AM
I have both a HiFiBerry DAC and Technics 1200 (+ puffin phono stage) that i'd like to run though the Crack w/o having to swap interconnects.  Is it advisable to add a 2nd set of inputs to the Crack?  Or should I just use an RCA splitter?
Offline Jameson
  • Intern in Chief
Reply #1 on: August 28, 2020, 03:25:15 AM
Something like a Schiit SYS is cheap and easy to put in the chain, and it keeps you from having to add more inputs, holes, and a switch into the Crack itself. I also built an input switch that is separate from the Crack and that was pretty easy to do
Jameson O'Guinn
Managing Partner
Offline martinman
Reply #2 on: August 28, 2020, 05:34:56 AM
Ah nice, thanks!
But how would the multiple volume pots play into the signal chain?
HiFiBerry (volume)
SYS (volume)
crack (volume)
do I just set the first 2 to max and control via the Crack pot  (heh...)?
Offline Jameson
  • Intern in Chief
Reply #3 on: August 28, 2020, 05:56:55 AM
That’s what I do. You could set things slightly under 100% or whatever works for you, but just control the volume with the Crack
Jameson O'Guinn
Managing Partner
Offline Laudanum
Reply #4 on: August 28, 2020, 11:43:57 AM
I have a Schiit SYS but use it a little differently.   I have it set up so I can run a DAP either through a Foreplay preamp then into a hybrid headphone amp or directly into the hybrid headphone amp.  At any rate,  I leave the volume up all the way on the SYS.   It's totally transparent (to my ears anyway).
Desmond G.
