Power switch alternative
lina · 1456
Offline lina
on: September 11, 2020, 12:23:35 PM
Instead of the supplied rocker switch, I'd like to use a rotary switch. I saw somebody post the ratings for what they thought was the stock switch in an old thread, and if they're correct I think this switch should be good (SPST, 125V, 12A - AC). Just want to make sure tho. Thanks!
https://www.digikey.com/product-detail/en/c-k/H10107RR05Q/H10107RR05Q-ND/3753429
Reply #1 on: September 11, 2020, 12:31:22 PM
If you're outside of the US, the 125V rating won't be enough.  The body of the rotary switch is going to hit the IEC power entry module if you try to put it in the same hole, but if you're planning to use a rotary switch from the start, I would wager that you're not using the panel we provide.
Offline lina
Reply #2 on: September 11, 2020, 12:36:23 PM
Yeah, I'm getting a panel milled. :P I am in the US, but I'm actually looking at emigrating. What voltage/amperage ratings should I aim for that wouldn't fail elsewhere?
Reply #3 on: September 11, 2020, 12:37:53 PM
I'd look for 250V/0.5A as a bare bones minimum for a 240V app, 1A or better for a 120V app.
« Last Edit: September 11, 2020, 02:40:20 PM by Paul Birkeland »
Reply #4 on: September 11, 2020, 02:28:56 PM
The startup transient current can be pretty heavy - it's only for a moment, but it's the exact same moment you actuate the switch. I'd look for 5 to 10 amps to ensure longevity.
Some countries require switching both power lines. That may not apply to home-built things, but I though I should mention it.
Reply #5 on: September 11, 2020, 04:52:45 PM
According  to the data sheet that' swhich is rated  6A-250vac as well as 12A-125vac. If it fits,should be ok...John
Offline lina
Reply #6 on: September 11, 2020, 07:57:09 PM
Oh duh. Well groovy! Gonna look great  ;D Thanks folks!
Reply #7 on: September 12, 2020, 01:58:36 AM
But you'll need to find a different online seller. Digi Key has no stock and a minimum order of 54 units  >:(.
Offline grufti
Reply #8 on: September 12, 2020, 02:16:48 PM
This might work, but don't take my word for it. It is in stock and 1 is the minimum order.
https://www.mouser.com/ProductDetail/CK/H20207RR01Q?qs=LgMIjt8LuD89nPtgbocxzA%3D%3D
