Problem with Integration upgrade [resolved]
cpditter · 36400
Offline cpditter
Reply #15 on: September 20, 2020, 03:57:32 PM
Terminal 53 is 166v
Chuck Ditter
Reply #16 on: September 20, 2020, 04:06:50 PM
How about the voltage at X on each side of the PC board?
Your C4S current sources are working properly, as we see about 40mA of current being pulled across the power supply resistors.  The only real issue that I think you're having is that the four zener diodes on the PC board don't appear to be pulling down the regulated rail.  Measuring the voltage between them will provide another helpful data point.
Offline cpditter
Reply #17 on: September 20, 2020, 04:13:38 PM
x on the B side is 53.6v
x on the A side is only reading a few 3-4mv
Chuck Ditter
Reply #18 on: September 20, 2020, 04:16:39 PM
So x on the B side being 53.6V would suggest that Ob should be around 107V, which is what we are aiming for.
X on the A side being 3-4mV means either those zener diodes on that side aren't well soldered or maybe (but less likely) the ground jumper isn't well connected.
Offline cpditter
Reply #19 on: September 20, 2020, 04:18:55 PM
OK, I'll resolder that Zener diode and resolder the ground wire and then check again...will do in the a.m. when I am fresh!
Thanks again for sticking with me on this...
Chuck Ditter
Reply #20 on: September 20, 2020, 04:45:56 PM
It's also worth double checking that all the zener diodes have the correct part number written on them.
Offline cpditter
Reply #21 on: September 21, 2020, 04:25:24 AM
Good morning
I desoldered the ground jumper and the zener diode joints.  That resulted in both readings at x now being 53-54v
My other reading:
still at 122 and 123v on the transistor pins and
Term 56 126v
Sorry I could not verify the values on the zener diodes without unsoldering them all...
Chuck Ditter
Offline cpditter
Reply #22 on: September 21, 2020, 05:02:18 AM
Correction on last post line 1, meant to say resoldered, not desoldered.
thx
Chuck Ditter
Reply #23 on: September 21, 2020, 05:20:01 AM
Term 56 126v
Both x pads being 53-54 is a good sign.  That's half the zener stack on each channel.  The voltage at the metal tab should be about 2x that.
What voltages do you get at OA and OB? Can you reflow the center leg of each MJE5731A and reheat both ends of each zener diode connected to OA and OB?
Offline cpditter
Reply #24 on: September 21, 2020, 05:48:54 AM
Hi
OA and OB both reading 107v
Chuck Ditter
Reply #25 on: September 21, 2020, 05:50:36 AM
OA and OB are connected to the metal tab of the MJE5731A, so I'm not sure why you have a different voltage there.  It may be that getting good probe contact on the metal tab is a bit of a problem in your case for some reason.
Either way you're OK to continue with the build.
Offline cpditter
Reply #26 on: September 21, 2020, 11:15:50 AM
Chuck Ditter
Offline cpditter
Reply #27 on: September 22, 2020, 04:55:11 AM
Hi:
The rest of the build went fine...up and running, will give it a good listen tonight.
Thanks again for the assistance...guess my soldering skills (which are probably not great to start with) were really rusty when I started this process :)
Chuck Ditter
Reply #28 on: September 22, 2020, 05:05:59 AM
I'm glad to hear you got it up and running!
Offline cpditter
Reply #29 on: September 23, 2020, 03:11:15 PM
Hi:
I've now listened to my Reduction with the newly-added Integration upgrade for about two days...
What I'm hearing so far is this:
Overall noise floor is reduced...not that it was bad before but definitely very quiet now.
Gain is noticeably higher so I'm listening with the volume at a lower setting than previously...used to be a very dramatic difference between phono and a line source like my CD player...now that difference is much less.
Can't say I'm hearing a big difference in bass response per se...but, some of the lower end like kick drum seems tighter and just pops out of the mix better I feel.
Thanks again for the help on the build
Chuck Ditter
