Green Wire Connection - Quick Question
tvr2500m · 1837
Offline tvr2500m
on: October 08, 2020, 08:50:33 AM
I am finally getting to be building my S3X 3. I'm very excited about getting it glowing. I have a question about the green twisted wire pair going from PT-10 terminals 7 and 9 and to terminal strip H3U and H6U. From the assembly manual, it doesn't matter which wires connect to which terminals, and that either ends of either green wire can attach to either pair of terminals. That is, say, that the wire from PT-10 terminal 7 has to connect to terminal strip H3U, and the other wire has to connect between 9 and H6U, or the other way around.
After attaching the wires to the transformer terminals, then twisting them together, whichever wire is closer to the terminal strip lugs can be solder to that lug.
Is this correct?
Thanks.
« Last Edit: October 08, 2020, 10:52:24 AM by tvr2500m »
Offline Thermioniclife
Reply #1 on: October 08, 2020, 10:01:27 AM
That is correct.
Offline tvr2500m
Reply #2 on: October 08, 2020, 10:52:34 AM
