plate choke inductance at rated current
ee · 1289
Offline ee
on: November 06, 2020, 05:21:03 AM
I'm looking at plate choke ratings.
- (plate) choke has a rated inductance measured at a current. Is the actual inductance dependent on the choke's current around that measured rating?
For example, using a rated plate choke that's 50H @ 60 ma in a circuit whose constant current is 30 ma the H would increase perhaps 2x since the current was half of rated measurement?
If the H does change is there a good estimate for what H might be based on current if I don't have equipment to measure?
Thank you for your help.
Eric
Bottlehead Stereomour 2a3
Fostex FE206En in Vulcan (BIB BLH)
VPI Scout 1.1 with classic platter
Lyra Delos
Manley Chinook phono pre
Creek Destiny 2 CD
Audio Art Power Cables
Reply #1 on: November 06, 2020, 05:25:51 AM
Yes, the inductance will go up a bit, but I wouldn't expect 2x.
You can buy a cheap LCR meter and measure the inductance with no AC current.  The inductance at 30mA will be somewhere between that number and 50H ;)
Reply #2 on: November 06, 2020, 08:49:06 AM
There is a continuum of choke designs, which I think of as three varieties:
1) Designed for large AC flux and small DC flux
2) Designed for comparable levels of AC and DC flux
3) Designed for large DC and small AC flux
Type 2 includes series feed transformers and parallel feed plate chokes. These are sometimes called "linear inductors" because the air gap dominates the AC permeability over a wide range of AC flux. For these, the inductance decreases slowly with the DC flux, typically falling less than 20% at maximum DC current, depending on design choices.
Note that Type 3 is typical of power supply filter chokes. To use regular filter chokes as parafeed inductors, it's a good idea to de-rate the DC current by 20-50% to leave some flux range for the AC currents.
The above notes are still a gross simplification of plate choke performance, but this is a forum post, not a textbook  :^)
Reply #3 on: November 06, 2020, 10:03:00 AM
I thought that was my post!
