No Sound on Left Channel
lycos · 1945
Offline lycos
on: November 06, 2020, 04:54:18 PM
Hi,
I have just finished building crack.
I have done the resistance and voltage test.
The sound only comes on right channel. No sound on left channel.
I have reflowed every joint but the problem still persists.
How do I find the source of this issue?
Thanks.
« Last Edit: November 06, 2020, 05:18:31 PM by lycos »
Reply #1 on: November 06, 2020, 05:22:26 PM
Can you post your voltages on terminals 1-10?
I don't suppose you're using a 1/4" to 1/8" adapter?
Offline lycos
Reply #2 on: November 06, 2020, 05:48:47 PM
Thanks for prompt reply.
Will do the voltage test again
Yes, Im using 3.5mm to 6.35mm adapter.
I dont think there’s issue  with adapter because its working fine when i
plugged it to my solid state amp
« Last Edit: November 06, 2020, 05:50:37 PM by lycos »
Offline lycos
Reply #3 on: November 06, 2020, 05:57:35 PM
1. 86.3
2. 178
3. 0
4. 178
5. 80.6
6. 0
7. 119
8. 0
9. 109
10. 0
Reply #4 on: November 06, 2020, 08:06:18 PM
I would very, very, very strongly suggest trying a pair of headphones without the adapter.  There are a few varieties of those adapters that don't work all that well.  We used to keep a bin of them on the wall at the old office because we would have to throw them away so frequently.
Offline lycos
Reply #5 on: November 07, 2020, 12:16:15 AM
I found the issue, the foot of 3k 10w resistor was slightly loose and missed during resoldering.
Its all working now.
Thank you!!
