Installing 33K and 75K resistors to volume pot (no lines on resistors)[resolved]
Colonl_Charisma · 1712
Offline Colonl_Charisma
Hi all,
I received my 33K and 75K RN55D resistors from Digi-Key. My Crack (no Speedball) is very loud even at low volumes + a little channel imbalance until I increase the volume. I saw FAQ #3 provides a solution, but I’m unsure of the correct orientation of the resistors since there are no lines on them.
« Last Edit: November 14, 2020, 03:48:18 PM by Paul Birkeland »
Ross
Fiio K11 R2R --> Bottlehead Crack --> HD600
Unable to post pictures at the moment, but the resistors are just brown with numbers indicating what they are.
Ross
Resistors don't have an orientation or direction. Just stick them in where Paul indicates in FAQ #3 and you'll be good to go.
cheers, Derek
Thank you! Thought I’d make sure before I did anything.
Ross
Just installed the resistors, let the tubes warm, and played some music. Everything sounds great!
Ross
