Bootlehead crack speedball [resolved]
Applemacman · 2429
Offline Applemacman
on: November 16, 2020, 04:38:34 AM
Im having issues with the bootlehead woth speedball, after having this working over a month im experiencing hissing, cracks pops and sometimes the loss of one channel. I did the chop stick test and found some joints would make noise when banged. So resoldered them but im still suffering from these really irritaing pops hisses and buzzes. Any help would be greatly appreciated?
« Last Edit: November 24, 2020, 07:14:08 AM by Paul Birkeland »
Reply #1 on: November 16, 2020, 04:57:42 AM
I would suspect you still have some solder joints that need to be touched up.  Are your DC voltages correct?
Offline Applemacman
Reply #2 on: November 16, 2020, 05:14:05 AM
Yes after building the unit they were ok, should these be checked again?
Reply #3 on: November 16, 2020, 05:15:33 AM
Yes.
Offline Applemacman
Reply #4 on: November 16, 2020, 05:34:45 AM
In respects of rhe dry joints are you able to point me in a direction bearing in mind my issues mesing would they be in a specific area, eg which has cayse the loss if the right channel?
Reply #5 on: November 16, 2020, 05:37:31 AM
The best answer is to do all of them.  I can reflow all the joints in a stock Crack in under 20 minutes, and a Speedball with a Crack in about 30 minutes.  The only ones I wouldn't reflow are the ones on the power switch and the pins on the 9 pin socket with the LEDs.
Otherwise knowing the voltages would be very helpful in narrowing down where this issue might be.
Offline Applemacman
Reply #6 on: November 23, 2020, 07:46:01 AM
Sorry was a bit busy with work, well when I built the amp with the speedball the voltages were ok. After using a month im now getting the below reading and some are higher than they should be.
1.  70.3 Volts
2.  159 Volts
3.   0 volts
4.   159 Volts
5.   155 volts
6.    0 Volts
7.    95.7 volts
8.    0 Volts
9.    158 Volts
10.   0 vilts
5 and 9 concern me alot they are way above the figure shown.
Reply #7 on: November 23, 2020, 02:21:53 PM
Those voltages indicate a likely issue with the small Speedball board.  Most frequently I would expect to see that kind of issue when the center leg of the MJE-350 on the offending side isn't soldered well enough.
Offline Applemacman
Reply #8 on: November 24, 2020, 06:03:24 AM
Thanks mate for the advice now voltages are in correct range. This weekend I will reflow the solder joints throughout to see if i can fix the crackling and poping noises, will let you know.
« Last Edit: November 24, 2020, 06:18:01 AM by Applemacman »
Offline Applemacman
Reply #9 on: November 29, 2020, 06:15:24 AM
Ok want to thank paul Birkeland for all the help.
I have seem to resolved the issues of the cracking and poping sounds. I was reading elsewhere and must admit didnt think about it. The pins on the vacuum tube that came with the amp kit were absolutely dirty I gave them a good cleaning and the cracking and popping sounds have gone.
So if you expeience this issue try cleaning the pins of the valve.
« Last Edit: November 30, 2020, 05:47:32 AM by Applemacman »
