230v Crack with Speedball - High Readings (Resolved)
Jimb0 · 1983
Offline Jimb0
on: November 30, 2020, 04:53:39 PM
230v Crack with Speedball tested on my step up converter
Getting some high readings here:
Big Board
OA - 168v
OB - 121v
Small Board
OA - 121v
OB - 168v
Pics
https://imgur.com/a/4G28eta
« Last Edit: December 04, 2020, 01:16:03 PM by Jimb0 »
Offline Jimb0
Reply #1 on: December 01, 2020, 04:02:17 AM
Resistance checks
3) 3.4ohms
6) 2.5 ohms
7) 2.35k ohms, continues to rise
B3) 2.6k ohms, continues to rise
B6) *
RCA Jacks Center Pins
The red and black jacks are reading ohms not k ohms like in the manual
Black 93ohms
Red 95ohms
Big Board Resistances
OA - *
OB - *
Reply #2 on: December 01, 2020, 05:38:04 AM
The big board won't work if the small board isn't working first.  I would pull the 6080 and just run the amp with the 12AU7, then focus your debugging efforts there.
Does the 12AU7 glow?
Do the LEDs on the 9 pin socket glow?
I suspect the answer to one or both of these questions is no.
Offline Jimb0
Reply #3 on: December 01, 2020, 09:52:28 AM
Hey PB. I rechecked it without the 6080 and both the 12AU7 tube and the 2 LED's on the 9 pin socket were glowing
Reply #4 on: December 01, 2020, 11:34:42 AM
Can you check the voltages with just the small tube installed?
Offline Jimb0
Reply #5 on: December 01, 2020, 01:45:08 PM
Small Board
OA - 85v
IA - 232v
G - 0v
IB - 232v
OB - 139v
Reply #6 on: December 02, 2020, 05:36:51 AM
OK, it looks like you have some debugging to do on the front half of the amp.  139V is definitely an issue.
I would follow the flow chart on page 20.  If that isn't helpful, knowing the DC voltage at A8 could be helpful.
Offline Jimb0
Reply #7 on: December 04, 2020, 01:15:47 PM
Hey PB. It turned out I was using a 12AX7 when I last tested it. I had purchased a lot of 12AU7's on eBay and the seller wasn't aware of the 12AX7's in the lot. The amp was actually working fine the first time around. I assumed all the tubes that I was testing were 12AU7's so I thought for sure a part failed. Sorry for wasting some of your time. Always appreciate the help you provide. Have a good weekend PB!
