Voltage Check Failure
tayjj1987 · 3164
Offline tayjj1987
on: December 01, 2020, 06:35:35 AM
I recently completed my Mainline where I passed the resistance checks but failed the voltage checks. I have reflowed every solder joint on the board twice and the voltage checks are still the same.
Specifically, I will have the following voltages:
TerminalVoltage (DC)
+275vDC on the Power Supply Board211V
+6.3vDC on the Power Supply Board1.7V
IA on the A side C4S Board209V
IA on the B side C4S Board209V
Breg Regulator Board (both sides)158V
-reg Regulator Board (both sides)-57V
Kreg Regulator Board (both sides)46V on one side and 54.8V on the other side
Curiously, I will read 270V at +275vDC on the Power Supply Board when I first turn on the power but the voltage will drop almost immediately and stabilise around 211V.
I tried experimenting with how the voltage measurements was done. Instead of clipping the black negative lead of the volt-ohm meter to the ground buss at terminal 7, I tried clipping the black negative to the E terminal of the IEC power inlet. When I do so, all the voltages are within 10% range except for the voltage at +6.3vDC on the Power Supply Board where I will have a measurement of 58V.
I am at a lost what does of all this information meant. Any help will much appreciated!
Reply #1 on: December 01, 2020, 07:43:13 AM
How was the test on page 52 where you test that power supply board?  If it passed there, but now you see 1.7V on the 6.3V output, then there's a short between pins 4 and 5 on one of the 6C45P sockets most likely.
Seeing -57V on a -reg on a regulator board tells me you have a missing or loose ground wire.  The voltages changing dramatically when you use the earth terminal instead of terminal 7 also points to this.
A reading of 58V on the 6.3V pad on the power supply board is OK.  What DC voltage do you get between the + and - pads on the 6.3V output of the power supply board?
I would be nearly certain by what you've posted that you have some loose connections that need more heat with the soldering iron.
Offline tayjj1987
Reply #2 on: December 02, 2020, 04:53:51 AM
Thanks for the help, Paul.
I did not encounter any issues when performing the tests on page 52. Thus I continued building the Mainline and only encountered voltage issues at the end of the build.
The DC voltage between the + and - pads on the 6.3V output of the power supply board is +1.7V and -4.7V respectively.
I wasn't expecting any more loose connections because I was checking for that when I reflowed the solder joints. I guess I may have missed something. I will look into the areas you mentioned over the weekend.
Reply #3 on: December 02, 2020, 05:34:29 AM
The voltage between the + and - pads would mean putting the black probe on the - pad and the red probe on the + pad.  From what I can gather from your measurements, you seem to have 6.3V coming out of there.
