Moreplay voltage check [resolved]
sfojws · 1339
Offline sfojws
on: December 12, 2020, 08:52:18 AM
Finished the build last night, and checked resistances (twice, writing the results, the second time). When checking voltages today, the manual calls for 225-275V at terminals 10 & 20. However, these terminals are not connected to anything. Do the advised readings apply to other terminals? Thanks. Had a great time building, can't wait to start listening. The power amp is a Hafler DH220 that I assembled in 1985, by the way.
« Last Edit: December 12, 2020, 01:27:33 PM by Paul Birkeland »
John
Offline Alonzo
Reply #1 on: December 12, 2020, 09:40:16 AM
My manual says 1 and 11.  No voltage measurement value at 10 or 20.  There's an DMM check early in the build at terminal 10 but no voltage checks.
Alonzo
Offline sfojws
Reply #2 on: December 12, 2020, 10:59:28 AM
Fortunately, the manual I have also has 1 & 11. I had dowloaded the file before the first shipment went out (not too eager, huh?), and I sense that the correction was made shortly afterward.
The first (short) test listening was quite good. Starting to stain the base now, and once the final coat dries, and the rubber feet have been installed, it'll be time for more serious listening.
John
