Bottlehead Kits
Crack
Audio signal on B+
Audio signal on B+
Shamsyrup
1843
Shamsyrup
Jr. Member
Audio signal on B+
January 09, 2021, 08:09:59 AM
Hope everyone is doing fine. I am getting audio signal on my B+ line. Is it normal ? I have also taken some measurements on the DC filtering stages. Attached all the pictures. All measurements were taken when the amp was fully cranked up. Are these measurements normal ?
Thank you.
Tom-s
Sr. Member
Re: Audio signal on B+
Reply #1 on:
January 09, 2021, 08:23:56 AM
You're watching power supply ripple.
Edit. That how i interpret the power supply filter results. But i can't explain the 1khz tone you have on the B+?
Last Edit: January 09, 2021, 08:26:15 AM by Tom-s
Shamsyrup
Jr. Member
Reply #2 on:
January 09, 2021, 08:27:38 AM
What about the audio signal on B+ ? That is not power supply ripple.
The 1khz tone was fed to the input of the amp through a function generator.
Tom-s
Sr. Member
Reply #3 on:
January 09, 2021, 08:29:58 AM
That's your amplifier functioning.
Shamsyrup
Jr. Member
Reply #4 on:
January 09, 2021, 08:32:29 AM
So it is totally normal to see audio signals on high voltage DC B+ power rail ?
Global Moderator
Hero Member
Reply #5 on:
January 09, 2021, 08:59:15 AM
The output signal current flows through the power supply, and the impedance of a 220uF cap at 1000Hz is about 0.7 ohms, so there will be some signal.
What was the signal level? And what was the load (i.e. headphones plugged in? what impedance?)
Shamsyrup
Jr. Member
Reply #6 on:
January 09, 2021, 09:56:19 AM
Signal level was 1 volt and the load impedance was 300ohms.
Bottlehead Kits
Crack
Audio signal on B+
